Linear Algebra - Change of Basis
The discussion revolves around a linear algebra problem involving change of basis in R^2. The original poster presents a linear transformation T defined with respect to one basis (B) and seeks to find its representation with respect to another basis (C). The problem includes checking properties like the determinant and trace of the matrices involved.
  • Mixed
  • Participants discuss the calculation of change of basis matrices and their application to find the transformation matrix in a different basis. There are attempts to verify the correctness of these matrices through properties like trace and determinant. Some participants express uncertainty about their calculations and question the validity of their approaches.
The conversation includes various attempts to derive the change of basis matrix and the transformation matrix. Some participants have provided corrections to others' methods, and there is an ongoing exploration of different interpretations and calculations. There is no explicit consensus, but guidance has been offered regarding the correct formulation of the change of basis matrices.
Participants note potential discrepancies in their calculations and mention the influence of external resources like textbooks, which may contain errors. The discussion reflects a collaborative effort to clarify the mathematical concepts involved.
kehler
Let B & C be the following subsets of R^2
B= {[3 1] , [2 2]} (the vectors should be in columns instead of rows)
C= {[1 0] , [5 4]}
Let T: R^2 -> R^2 be the linear transformation whose matrix with respect to the basis B is
[2 1]
[1 5] (the brackets should be joint, it's a 2 x 2 matrix)
Find the matrix T with respect to C. Check your answer by finding the determinant and the trace of each matrix.
I found the change of basis matrix from B to C to be
[(7/4) (-2/4)]
[(1/4) ( 2/4) ] (again a 2x2 matrix)
I did this by multiplying the change of basis matrix from the standard basis to C, with the change of basis matrix from the B basis to the standard matrix like this:
[1 (-5/4)] [3 2]
[0 (1/4)] [1 2]
I then multiplied the given matrix by the change of basis matrix from B to C to get
[3 (-3/4)]
[1 (11/4)]
I thought my answer was correct but the trace for the matrix I got is 8.25 whilst the trace of the original matrix is 7. They should be the same, right??
Can anyone see where I went wrong? I'm not sure if I got the change of basis matrices right :S. The columns of the set B should form the change of basis matrix from B to the standard basis, shouldn't they?
Any help would be appreciated :)
[1 (-5/4)] [3 2]
[0 (1/4)] [1 2]
You've actually done the exact opposite here:
The matrix for going from the standard basis (S) to C is actually:
[tex]\overleftrightarrow{P}_{C \leftarrow S} \leftrightarrow \left( \begin{array}{cc}<br /> 1 & 5 \\<br /> 0 & 4 \end{array} \right)[/tex]
While the matrix for going from B to S is actually:
[tex]\overleftrightarrow{P}_{S \leftarrow B} \leftrightarrow \left( \begin{array}{cc}<br /> \frac{1}{2} & \frac{-1}{2} \\<br /> \frac{-1}{4} & \frac{3}{4} \end{array} \right)[/tex]
You can check these by operating on each of the basis vectors in S (i.e. {[1,0],[0,1]}) with
[tex]\overleftrightarrow{P}_{C \leftarrow S}[/tex] , to make sure you get the basis vectors of C; and by operating on each of the basis vectors in B with
[tex]\overleftrightarrow{P}_{S \leftarrow B}[/tex] , to make sure you get the corresponding basis vectors in S.
You can then easily obtain the change of basis matrix from B to C by using :
[tex]\overleftrightarrow{P}_{C \leftarrow B} = {\overleftrightarrow{P}_{C \leftarrow S}}{\overleftrightarrow{P}_{S \leftarrow B}}[/tex]
Are you in MATH1116 at ANU? If you're not then my lecturer's been doing some hard core plagiarism. :P
Sorry I don't actually have an answer for you... I got the same as you but the trace that I calculated was 5.75...
:S
:S
Muso, the answer for [tex]\overleftrightarrow{T_c}[/tex] should be:[tex]\overleftrightarrow{T_c} {\leftrightarrow} \left( \begin{array}{cc} \frac{83}{4} & \frac{-277}{16} \\ 17 & \frac{-55}{4} \end{array} \right)[/tex]
If you show me your work, I can tell you where you went wrong.
Okay, I got P(C<--B)=
[7/4 -1/2]
[1/4 1/2] (2x2 matrix)
so [T]C=P(C<--B)[T]B=
[7/4 -1/2][2 1]=
[1/4 1/2][1 5]
[3 -3/4]
[1 11/4]
Much appreciated. :)
[7/4 -1/2]
[7/4 -1/2][2 1]=
[1/4 1/2][1 5]
[3 -3/4]
[1 11/4]
Okay, your first error is that your [tex]\overleftrightarrow{P}_{C \leftarrow B}[/tex] Matrix is incorrect.
Your second error is that
[tex]\overleftrightarrow{T_C} =\overleftrightarrow{P}_{C \leftarrow B} \cdot \overleftrightarrow{T_B} \cdot \overleftrightarrow{P}_{C \leftarrow B}^{-1}[/tex]
NOT just
[tex]\overleftrightarrow{T_C} =\overleftrightarrow{P}_{C \leftarrow B}} \cdot \overleftrightarrow{T_B}[/tex]
Why don't you show me how you got your [tex]\overleftrightarrow{P}_{C \leftarrow B}[/tex]?
I used the [c1 c2 | b1 b2] ~ [ I | P(C<--B)] formula
so I got
[1 5 | 3 2] ~
[0 4 | 1 2]
[1 0 | 7/4 -1/2]
[0 1 | 1/4 1/2]
So P(C<--B)=
[7/4 -1/2]
[1/4 1/2]
Thanks
Hmmm... I've never seen that formula before, but I can derive a correct version of it for you:
[tex]\left( \begin{array}{cc} \vec{c_1} ,& \vec{c_2} \end{array} \right) = \overleftrightarrow{P}_{C \leftarrow B} \cdot \left( \begin{array}{cc} \vec{b_1} ,& \vec{b_2} \end{array} \right)[/tex]
since, by definition, the change of basis matrix will change the basis vectors of B into those of C.
And so,
[tex]\left( \begin{array}{cc} \vec{c_1} ,& \vec{c_2} \end{array} \right) \cdot \left( \begin{array}{cc} \vec{b_1} ,& \vec{b_2} \end{array} \right)^{-1} = \overleftrightarrow{P}_{C \leftarrow B} \cdot \left( \begin{array}{cc} \vec{b_1} ,& \vec{b_2} \end{array} \right) \cdot \left( \begin{array}{cc} \vec{b_1} ,& \vec{b_2} \end{array} \right)^{-1} =\overleftrightarrow{P}_{C \leftarrow B}[/tex]
Try this formula, and don't forget to take the inverse.
Thank you! I think my textbook is wrong... :S
Your welcome, wht do you get for [tex]\overleftrightarrow{P}_{C \leftarrow B}[/tex] now?
I got
[-3/4 13/4]
[-1 3]
Is that right?
muso07 said:
I got
[-3/4 13/4]
[-1 3]
Is that right?
Yup, did you get the right [tex]\overleftrightarrow{T_c}[/tex] now?
Yep. Or at least the traces and determinants agree now. :)
:S
Yes I am. Lol. Are u done with the assignment? I'm still stuck on a couple of questions :(
Thanks, gabbagabbahey :)
WOW! what are the odds of that?!:bugeye::smile: And you're welcome:smile:
I've done everything but the first and last questions. Need help with anything?
I'm stuck on the last one too! I just posted it actually...
And question 3 and 5. I've tried expanding q3 but I'm not getting anywhere :(. For q5, I'm having a bit of trouble trying to explain b and c.
U need help with the first question?
I actually found the geometric series by trial and error. Then I just showed that the sum of my series from n=10 to infinity is less than 10^-6.
yeah my tutor did an example for the first one and basically he used 1/n! from 10 to infinity but that's not a geometric series, so... :S
With 3 expand and factor out x^4 on the denominator and numerator. You should get a limit of -10/3.
And with 5, solve for r^3-9r^2-12r+20=0, you should get r=-2, 10, 1. Then yk is the solution with initial values as given in the question. yk=a(-2)^k+b(10)^k+c(1)^k and solve for a, b, c
Ahh thanks :).. I finally got ques 3. Expanding functions is such a pain!
Try using fractions for both the 'a' and 'r' in your geometric series.
  • · Replies 32 ·
  • · Replies 69 ·
12K
