Thread Closed
stochastic processes
Share Thread Thread Tools
Sep13-08, 10:30 AM   #1
Click image for larger version
I know that per definition [tex]E(N)= \sum P(N=k) \cdot k [/tex]. But how can I rewrite the above expectation towards the 'usual definition'?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Sep13-08, 11:03 AM   #2
Recognitions:
Homework Helper Homework Help
The expression
[tex]
E(\mathbf{N}) = \sum_k \Pr(N=k) \cdot k
[/tex]
is the usual definition for the expectation of a discrete random variable. I'm not sure what alternative you refer to. You will see, in books on probability theory, this sum written in the form
[tex]
E(\mathbf{N}) = \int x \, dP(x)
[/tex]
Edit: I was unable to view your attachment.
(a Riemann-Stieltjes integral), which reduces to the sum you (and I) have written. I doubt this is what you seek.
Sep14-08, 05:26 AM   #3
I'm getting seriously tired of getting approval for the attachements. I'll postphone the first exercise for now.
But can someone help me with the second exercise (X is a stochast that attains non-negative values):
Proof the following:
[tex] E(X) = \int_0^{\infty} \overline{F}(x) \mbox{d}x[/tex]
[tex]
\overline{F}(x) = 1- F(x) = 1-P(X \leq x) = P(X>x)
[/tex]
What I've got so far
[tex]
\int_{0}^{\infty} \overline{F}(x)\ \mbox{d}x = \int_0^{\infty} \int_x^{\infty} f(y)\ \mbox{d}y = \int_0^{\infty} \int_0^y f(x)\ \mbox{d}x = \int_0^{\infty} F(y)-F(0)\ \mbox{d}y = y \left( F(y) - F(0) \right)_{0}^{\infty} +E(y)
[/tex]
What's going wrong in my solution?
Sep14-08, 07:43 AM   #4
Recognitions:
First, I've never seen the result you are trying to prove - but that doesn't prove it is written incorrectly. I know of the following result:
If the random positive random variable (so that [tex] F(0-) = 0 [/tex], then
[tex]
E(X) = \int_0^\infty \Pr(X > x) \, dx = \int_0^\infty \Pr(X \ge x) \, dx
[/tex]
although the integral may be infinite. Is this what you are discussing?
Second, your integrals, as written, don't make any sense - you need to integrate with respect to two variables, not just one. To point:
[tex]
\int_0^\infty \, \int_x^\infty f(y) \, dy
[/tex]
is meaningless without a [tex] dx [/tex] as well.
Sep14-08, 11:22 AM   #5
Quote by statdad View Post
[tex]
[/tex]
Well... its the expectation just written in another form which I'll have to proof.
[tex]
[/tex]
Yes you're right so we get:
[tex]\int_{0}^{\infty} \overline{F}(x)\ \mbox{d}x = \int_0^{\infty} \int_x^{\infty} f(y)\ \mbox{d}y\ \mbox{d}x = \int_0^{\infty} \int_0^y f(x)\ \mbox{d}x\ \mbox{d}y = \int_0^{\infty} F(y)-F(0)\ \mbox{d}y = y \left( F(y) - F(0) \right)_{0}^{\infty} +E(y) [/tex]
Statdad, what am I doing wrong here?
Sep14-08, 12:53 PM   #6
Recognitions:
You are getting caught up in notation.
When you write (in the middle of your work)
[tex]
\int_0^\infty \, \int_x^\infty f(y) \, dy dx = \int_0^\infty \, \int_0^y f(x) \,dx dy
[/tex]
why do you change the integrand from [tex] f(y) [/tex] to [tex] f(x) [/tex]? You are correct in saying that the order of integration changes, so the inner integral is w.r.t. [tex] x [/tex], but do you really need to write [tex] f(x) [/tex]?
Sep15-08, 02:55 AM   #7
What do you propose then?
Sep15-08, 08:17 AM   #8
Recognitions:
To answer
Quote by dirk_mec1 View Post
what you're doing in the double integral is not a change of variable - if that were the case, your step could be correct.
Try going through the same steps without changing from [tex] f(y) [/tex] to [tex] f(x) [/tex] at the aforementioned point. (And remember that when you integrate from [tex] 0 [/tex] to [tex] y [/tex] w.r.t. [tex] x, f(y) [/tex] will act like a constant.
Sep15-08, 02:08 PM   #9
To answer
Thanks statdad It worked. Now returning to the first exercise:
I want to proof that (note that my sum runs to a finite value n)
[tex] E[N]= \sum_{k=1}^{n} P(N \geq k) = \sum k \cdot P(N=k)[/tex]
So rewrite it to the usual definition.
Here's what I got so far (note the interchanging sum):
[tex] \sum_{k=1}^n P(N \geq k) = \sum_{k=1}^n \sum_{l=1}^n P(N=l) = \sum_{l=1}^n n \cdot P(N=l) [/tex]
I'm stuck here! What going wrong here?
Sep15-08, 02:29 PM   #10
Recognitions:
When you write
[tex]
[/tex]
you are essentially writing
[tex]
\Pr(N \ge k) = \sum_{l=1}^n \Pr(N=l)
[/tex]
This is not correct - the sum on the right here equals 1. In short, the expression for [tex] \Pr(N \ge k)[/tex] needs to be fixed.
Once that is one, you will have a double sum: reversing the order of summation (watch the indices) will get you where you need to be.
Sep15-08, 02:32 PM   #11
When you write
[tex]
[/tex]
Yes, you're right it should be:
[tex]\sum_{k=1}^n P(N \geq k) = \sum_{k=1}^n \sum_{l=k}^n P(N=l) = \sum_{l=k}^n n \cdot P(N=l) [/tex]
Is this correct?
Sep15-08, 02:40 PM   #12
Recognitions:
This
[tex]
[/tex]
portion of your most recent post is still not correct (I haven't even included the final equality)
When you write out the sum for [tex] \Pr(N \ge k) [/tex], where should the summation begin - at [tex] 1 [/tex] or some other value?
Sep15-08, 02:49 PM   #13
It should start at k but that's present in my post (#11) right?
Sep15-08, 02:58 PM   #14
Recognitions:
I'm sorry, you are correct - I'm preparing for class and in my haste looked at the wrong post.
Yes, the first portion of your statement is correct.
[tex]
[/tex]
Your error is in your next equality (which I did not include above)
Chew on this: The final double sum above can be written as
[tex]
\sum_{\substack{k=1\dots,n\\l \ge k}} \Pr(N = l)
[/tex]
Similar to the other question dealing with double integration, think about how you can reverse the order of summation (inner sum over some values of [tex] k [/tex], outer sum of [tex] l [/tex] while maintaining the same inequality relationships between the two variables of summation.
Sep16-08, 11:23 AM   #15
Thanks statdad I got it! You'll eventually get a summation that runs to 1 to l giving the l*P(N=l). I appreciate your effort in helping me!
Thread Closed
Thread Tools
Similar Threads for: stochastic processes
Thread Forum Replies
Stochastic Processes Calculus & Beyond Homework 0
Stochastic Processes Set Theory, Logic, Probability, Statistics 2
Re: How probable are realizations of stochastic processes? (was: General Physics 8
How probable are realizations of stochastic processes? (was: EEQT) General Physics 1
Stochastic equations. General Math 0
