Statics problem(chapter 2 of the book Vector Mechanics for Engineers)
The discussion revolves around a statics problem involving the calculation of the resultant force from three applied forces on a bracket. Participants explore various methods to determine the range of angles for which the magnitude of the resultant force is less than 120 lb, addressing both theoretical and practical aspects of the problem.
  • Homework-related
  • One participant attempts to set up equations for the net forces in the x and y directions but struggles to incorporate the condition of the resultant force being less than 120 lb.
  • Another participant suggests combining the two 30-lb forces into one force at an adjusted angle to simplify calculations.
  • There is confusion regarding the correct signs in the equations for net forces, with different interpretations of the direction of the x-axis leading to varying formulations.
  • Participants discuss the need to correctly account for the magnitudes of the combined forces and the implications of using trigonometric identities.
  • One participant reports an intermediate result of 45.69 lb but is questioned about the use of the angle 50º in their calculations.
  • Another participant clarifies the need to resolve forces in the direction of a resultant force and questions the introduction of an angle not previously discussed.
  • Ultimately, a participant claims to have derived a range for the angle θ as 27.39 > θ > 223 based on their equations.
Participants express differing views on the correct formulation of the equations and the interpretation of the angles involved. There is no consensus on the best approach to solve the problem, and multiple competing methods are presented.
Participants highlight limitations in their approaches, including potential mistakes in combining forces and the need for clarity in defining angles. The discussion reflects ongoing refinements and corrections to earlier claims without reaching a definitive solution.
This discussion may be useful for students studying statics, particularly those encountering similar problems involving resultant forces and angle calculations in engineering contexts.
Moayad
Three forces are applied to a bracket. The directions of the two
30-lb forces can vary, but the angle between these forces is always 50. Determine
the range of values of  for which the magnitude of the resultant of
the forces applied to the bracket is less than 120 lb.
http://www.gefoon.net/upload/7/278933efb0.jpg
2. Relevant equation:
Fnet,x=o
Fnet,y=0
i tried to get this problem solved by using different ways, but none of these have given me any answers.
@= the angle between 30-lb forces
i tried this one :
Fnet,x= 100 cos(30)-30 cos(@)-30cos(@+50)=0
Fnet,y=100sin(30)-30sin(@)-30sin(@+50)=0
but, this does not seem right for me because i am not going to have range of the angle and i did not use 120 ,and alos the TI-89 did not give me any thing.
however, i used another way,
120> -100 cos(150)+30cos(150)+30cos($)+30cos($+50)
i tried to solve by Ti-89 but also nothing happned.
$= the angle between the x-positive axis to the first 30-lb force.
my problem is i do not know how to deel with (the which the magnitude of the resultant of
the forces applied to the bracket is less than 120 lb.) ...
can anyone helps me with ASAP
Welcome to PF!
Hi Moayad! Welcome to PF! :smile:
(have a theta: θ :smile:)
Moayad said:
… i tried to get this problem solved by using different ways, but none of these have given me any answers.
It's Fnetx = 100 cos(30)+30 cos(@)+30cos(@+50)=0
Hint: F2 = Fx2 + Fy2 :smile:
(oh … and it might be easier to combine the two 30lbs forces into one force at θ + 25º first :wink:)
thanks man ...
can i ask more questions
is not Fnet,x = -100 cos(30)+30 cos(@)+30cos(@+50)=0
what about Fnet,y?
is it goin to be = 100sin(30)+30sin(@)+30sin(@+50)?
Thank you for help
Moayad was here
what about Fnet,y?
(what happened to that θ i gave you?)
if x is to the right, it's Fnet,x = -100 cos(30)-30 cos(@)-30cos(@+50)
if x is to the left, it's Fnet,x = 100 cos(30)+30 cos(@)+30cos(@+50)
(where did your "=0" come from? :confused:)
Your original Fnet,y was correct.
from the graph
is not the x to the right ?
sorry i did not use what you gave me, i' am going to use from now
thank you again
here again
i did this :
i used the x to the right, so
Fx=-100cos(30)-30cos(25-θ) , ( i combined the two 30lbs forces into one as you told me )
Fy=100sin(30)-30sin(25+θ)
F^2 = Fx^2 + Fy^2
l let F=120 ...(is it right?)
so,
Fx= sqrt((120)^2+Fy^2)
i pulged to to(Fx=-100cos(30)-30cos(25-θ) )
it became :
sqrt((120)^2+Fy^2)=-100cos(30)-30cos(25-θ)
and i pulged (Fy=100sin(30)-30sin(25+θ))
so,
my final equation is :
sqrt((120)^2+(100sin(30)-30sin(25+θ))^2)=-100cos(30)-30cos(25-θ)
then , i put it to the Ti-89 using the solve comand. i solved to the θ
but, it did not gave me a number or range of values
Moayad said:
from the graph
Hi Moayad! :smile:
i agree x is usually to the right …
but it's your decision …
the maths is only there to help you :rolleyes:
you're in control! :smile:
you can make x to the left if you want to, and in this case it's much easier, because it avoids all those minus signs! :wink:
Moayad said:
i did this :
F^2 = Fx^2 + Fy^2
Hi Moayad! :smile:
hmm …
i] you can't just write 30cos(25-θ) … the magnitude of two 30lb forces combined won't still be 30 (or even 60), will it? :wink:
ii] don't be so complicated :cry:
just square Fx and Fy, add them, and use cos²θ + sin²θ = 1 :smile:
Hi again ...
i usually make stupid mistakes ... sorry heh
i added them so what i got is 45.69 lb
i am going to work this out .. and i'll be back
thank you sooooo much
how did you get that?
you didn't use 50º, did you?
i used
30/sin(25)=R/sin(40)
R= the new force
Moayad said:
i used
R= the new force
wherever did 40º come from? :confused:
resolve in the direction of R: R = 30cos(25º) + 30cos(-25º) = … ? :smile:
i got it ... thank you for you help
i used the three equation
1- F=sqrt((Fx)^2+(Fy)^2)
F=120
2-Fx = -100 cos(30)-30 cos(θ)-30cos(θ+50)
3-Fy=100sin(30)-30sin(θ)-30sin(θ+50)
i pluged equation 2,3 to 1
and solve for θ
i got 27.39>θ>223
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 38 ·
  • · Replies 24 ·
