Object dropped from plane - where does it land?
  • Thread starter Thread starter x^2
    Plane
The discussion centers on calculating the distance a plane must be from a target group when dropping an object from a height of 227 meters at a speed of 60 m/s. The initial calculations incorrectly used the equation for vertical motion, leading to confusion about the time of fall. The correct approach involves determining the time it takes for the object to fall using the equation \(227 m = \frac{1}{2} g t^2\), where \(g\) is the acceleration due to gravity (9.8 m/s²). The correct time of fall is approximately 6.77 seconds, resulting in a horizontal distance of 406.2 meters from the target.
  • Understanding of kinematic equations for projectile motion
  • Basic knowledge of physics concepts, specifically gravity and free fall
  • Ability to manipulate algebraic equations
  • Familiarity with horizontal and vertical motion components
  • Study kinematic equations for projectile motion in detail
  • Learn how to derive time of flight for free-falling objects
  • Explore the effects of air resistance on projectile motion
  • Practice solving similar problems involving horizontal and vertical motion
Students in physics, educators teaching mechanics, and anyone interested in understanding projectile motion and its applications in real-world scenarios.
x^2
A plane is dropping an object from a height of 227m, such that it lands at a group of people on the ground. The speed of the plane is 60 m/s. How many meters before the group does the plane have to drop the object such that it lands at their position?
xf = xi + vix delta t + (1/2) ax(delta t)2
From my understanding, I need to break up the x and y components of this problem. If I can find the time it takes the object to hit the ground, I can multiply it by the plane's velocity and see what distance the plane must be from the observers for the package to hit its target.
227 m = 9.8t m/s^2
(227 m)/(9.8 m/s^2) = t
t^2 = 23.162
t = sqrt(23.162)
t = 4.813 seconds
Now that I have the time it took for the object to fall, I can multiply it by the plane's velocity to see how far in the x direction the object will travel in 4.813 seconds:
4.813 s * 60 m/s = 288.78 m
This is the answer I get, but it isn't correct. I can't see how multiplying the velocity by the time is wrong, but perhaps I have the wrong time?
Thanks,
x^2
x^2 said:
227 m = 9.8t m/s^2
Something is wrong with that equation, since the units are different on the 2 sides:
m ≠ s ⋅ m/s^2
m ≠ m/s
  • · Replies 38 ·
  • · Replies 18 ·
