How Does Rocket Mass Loss Affect Exhaust Gas Velocity for Lift-off?
  • Thread starter Thread starter PhyStan7
    Mass Momentum
The discussion revolves around the physics of rocket propulsion, specifically focusing on how mass loss during fuel consumption affects the exhaust gas velocity required for lift-off. The original poster presents a scenario involving a rocket with a specified mass and fuel consumption rate, seeking guidance on how to approach the problem without receiving a direct solution.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the rocket's mass, the force required for lift-off, and the velocity of the exhaust gases. There are discussions about modeling the rocket and gas as separate entities and using momentum principles. Some participants suggest using basic force equations while others consider the implications of mass loss over time.
Several participants have offered insights and alternative approaches, with some questioning the assumptions about the timing of lift-off and the need for calculus in the analysis. The conversation reflects a mix of interpretations and attempts to clarify the problem without reaching a consensus on the method or solution.
There is uncertainty regarding whether the problem is asking for the conditions at the moment of ignition or at a later time when some fuel has already been consumed. This ambiguity influences the approaches discussed.
PhyStan7
Hi, our teacher set this in class. I think its above what we have to know for the syllabus and have tryed to work it out but i don't think I am doing it right. I just want a few pointers, not the answer!
ok...
A rocket with mass 5000kg of which 4000kg is propellant is launched vertically. The fuel is consumed at a rate of 50kg per second. What is the least velocity of the exhaust gases if it is to release the rocket immediately after firing.
F=ma
Suvats
Momentum=mv
F=Change in mv/t
Ok i experimented a bit with it but had too many unknowns to really make much of it. I saw you could model the rocket and gas given off as 2 different particles acting in opposite directions. The momentum of the rocket equaling the momentum of the gas given off. This would mean the velocity of the gas cloud would be much greater than the velocity of the rocket at the 1 second mark.
I multiplied the mass of the rocket (and propellant) after 1 second by g to get 48510. I figured this is the weight of the rocket which acts downwards. The force provided by the gas cloud pushing the rocket upwards must exceed the weight of the rocket downwards for the rocket to move up. The mass of gas released is 50kg so i divided the minimum force needed by the amount of gas to get the acceleration which was 970.2.
Im pretty sure the working I've done is wrong as i haven't used the formula for momentum. I tryed expressing the velocity of the gas with the velocity of the rocket in the momentum formula and played around with substituting in stuff but havnt got anywhere.
I don't think the working can be too complicated, i just think there is something I am missing. Any hints or pointers would be appreciated to get me on the right track. Thanks
Is that word for word the problem statement? If I understand it correctly you are looking for the minimum velocity of the propellant gas in order for the rocket to lift off.
If that is the case, you only need f = ma. However you may prefer it in the form:
F = dp/dt = m2v2 - m1v1
I think you are right. I misread the actual question. That is a much simpler calculation for lift off since you are not worried about mass loss.
Ok I've had another look at it, thanks for the help. Is this right? At t=1 the rocket will have mass 5000-50kg, 4950kg. g downwards is 9.81 so the total force downwards is 48559.5
By modeling the gas cloud as a particle, it will have to exert an upward force of over 48599.5 for the rocket to move vertically.
F= change in mv/t and as F must equal 48599.5 (and t=1) F/m=v. Tge mass of the gas cloud is 50kg so the velocity of the cloud = 971.2 m/s.
It seems logical to me but i don't think the answer seems right. Any pointers would be appreciated, again i want to try and find the answer myself. Thanks
Let U = the combustion velocity of the gas
[tex]F = M \frac{dv}{dt} = \frac{dm}{dt}*U = M*g[/tex]
At lift off then you must have sufficient velocity of the combusted gas to achieve a minimum of M*g
Actually it is a little more complicated because M is not exactly M, because as you noted it is M - dm/dt. So I suppose it's a matter of whether lift off is at T=0 or T=1.
Your going to need a little calculus if you want to go this route. Your solution for the velocity of the gas will then not be constant but a function of time. For the question, are you sure it is not asking for the velocity at a time instant of 0? The other route seems a bit to complicated for the principles you are learning.
If you want to go the complicated route, then to get started
dmrocket/dt = - dmgas/dt
Thrust = [tex]\int[/tex][tex]\int[/tex] [tex]\ddot{m}[/tex][tex]\dot{V}[/tex] dm dv
*sorry if its hard to read, I suck at using latex
Yeh I am not sure about the time. I didnt think it was t=0 as i thought no gas would have been released. But I am sure which ever it is as long as I've done the right method my teacher won't mind. Thanks for the help guys!
[tex]Thrust = \int \int \ddot{m} \dot{V} dm dv[/tex]
Better?
