Intigration (volume of solids rotating about and axis)
  • Context: Graduate
  • Thread starter Thread starter jkw0002
    Axis Rotating Solids
The discussion focuses on the integration of solids of revolution, specifically analyzing a solid bounded by the planes x=1 and x=-1. The cross-sections perpendicular to the x-axis are defined as circles with diameters extending from the curves y = -1/√(1+x²) to y = 1/√(1+x²), and vertical squares with bases defined by the same curves. This setup allows for the calculation of volumes using integration techniques relevant to calculus.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of solids of revolution.
  • Knowledge of cross-sectional area calculations.
  • Basic proficiency in working with functions and curves.
  • Study the method of disks and washers for volume calculations.
  • Learn about the Shell Method for solids of revolution.
  • Explore applications of integration in calculating areas between curves.
  • Investigate the use of definite integrals in volume calculations.
Students and educators in calculus, mathematicians focusing on integration techniques, and anyone involved in geometric modeling of solids.
jkw0002
the solid lies between planes perpendicular to the x-axis at x=1 and x=-1 the cross-sections perpendicular to the x-axis are
A) circles whose diameters stretch from the curve y = -1/squrt(1+x^2) to the curve y = 1/squrt(1+x^2)
B)vertical squares whose base edges run from the curve y = -1/squrt(1+x^2) to the curve y = 1/squrt(1+x^2)
Welcome to PF!
A) circles whose diameters stretch from the curve y = -1/√(1+x²) to the curve y = 1√(1+x²)
B)vertical squares whose base edges run from the curve y = -1/√(1+x²) to the curve y = 1/√(1+x²)
Hi jkw0002! Welcome to PF! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
  • · Replies 20 ·
