Direction of Net Force?
by Rileyss123
Tags: direction, force
Rileyss123
Rileyss123 is offline
#1
Sep16-08, 09:27 PM
P: 10
This is a fairly simple Question but I just can't figure it out. If there is an object and there are two forces that act on the 5 kg object (say this object is located on the origin of an sy plane) and F1= 25 N and points in the 0 degrees direction and the other force, F2= 15 N and points 60 degrees counterclockwise from the x axis/ F1, what would be the direction of the total force counterclockwise from the x axis??
THANK YOU
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
cepheid
cepheid is offline
#2
Sep16-08, 09:55 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,198
Do you know how to do vector addition? If so, then this question is simple. You can, in fact, add up the x and y components separately:
x components:
(25 N) + (15 N)cos(60 deg)
y components
0 + (15 N)sin(60 deg)
So what angle does the resultant vector make with the x-axis?
Rileyss123
#3
Sep16-08, 10:03 PM
P: 10
Thanksss
Register to reply
Related Discussions
Solving for the Direction of a Force Classical Physics 4
Force and direction of motion Classical Physics 2
Normal force direction... Introductory Physics Homework 3
direction of magnetic force Introductory Physics Homework 2
direction of force Introductory Physics Homework 4
