Can You Help Me Debug My Java LinkedList Stack Implementation?
  • Context: Java
  • Thread starter Thread starter grouchy
    Java
The discussion revolves around debugging a Java implementation of a linked list stack. Participants are examining the methods for adding and removing elements from the stack, specifically focusing on the addHead, removeHead, and addTail methods. The conversation includes technical explanations and code reviews.
  • One participant expresses uncertainty about the removeHead method, particularly regarding the handling of the tail when the last object is removed.
  • Another participant critiques the addHead method, pointing out logical issues, such as the implications of having both head and tail null and the incorrect handling of the next pointer.
  • There is a suggestion that maintaining a tail pointer may not be necessary for a singly-linked list used as a stack.
  • A later reply indicates that the participant attempted to modify the addHead method but still encounters issues with the removeHead method not functioning as expected after multiple removals.
  • Participants discuss the implementation of the addTail method, noting that it incorrectly adds elements to the head instead of the tail.
  • One participant provides feedback on the addTail method, questioning the logic that leads to the head pointer being set to null during iteration.
Participants generally agree that there are issues with the addHead and addTail methods, but multiple competing views on the necessity of the tail pointer and the correct implementation of the linked list remain unresolved.
Limitations include unclear handling of the tail pointer in various scenarios, potential infinite loops in the addTail method, and assumptions about the state of the linked list during operations.
grouchy
Hi, i need to use a list class (provided and complete) and then use a Linkedlist class (need to add the methods) to get a stack going. I am having trouble with my remove from head method although I ain't too sure if my addHead method is right... I'd appreciate it if someone could look over my code and give me some pointers. I wrote in bold and caps where I aint sure. thx.
class Link
public Object data;
public Link next;
public Link(Object d, Link n)
data = d; next = n;
//LINKEDLIST CLASS AND MAIN
import java.util.Scanner;
class LinkList
private Link head; // reference to first Link
private Link tail; // reference to last Link
private int size;
public LinkList()
tail = null;
head = null;
public Object peekHead() // return reference to first Object
return head.data;
public Object peekTail() // return reference to last Object
return tail.data;
//THE ADD METHOD, NOT SURE IF DONE RIGHT
public void addHead(Object newData)
if (head == null)
head = new Link(newData, tail);
else if (head != null && tail == null)
tail = head;
head = new Link (newData, tail);
else
head.next = head;
head = new Link (newData, head.next);
public void addTail(Object newData)
//THE REMOVE METHOD
public Object removeHead()
Link removing = head;
if (head != null)
head = head.next;
return removing.data;
//MAIN METHOD
public static void main (String[] args)
Scanner scan = new Scanner(System.in);
int choice = 0;
LinkList first = new LinkList();
while (choice != 6)
System.out.println("What would you like to do? (enter the number)");
System.out.println("1 - Push onto Head of Stack.");
System.out.println("2 - Remove from Head of Stack.");
System.out.println("3 - Peek at Head of Stack.");
System.out.println("4 - Push at Tail of Stack.");
System.out.println("5 - Peak at Tail of Stack.");
System.out.println("6 - Close Program.");
choice = scan.nextInt();
switch(choice)
case 1:
System.out.println("What do you want to push on Head?");
Object pushingHead = scan.next();
first.addHead(pushingHead);
break;
case 2:
System.out.println("Removing: " + first.removeHead());
break;
case 3:
System.out.println("Peeking at Head of Stack: " + first.peekHead());
break;
case 4:
System.out.println("What do you want to push on Tail?");
Object pushingTail = scan.next();
first.addHead(pushingTail);
break;
case 5:
System.out.println("Peeking at Tail of Stack: " + first.peekTail());
break;
case 6:
System.out.println("Good Bye!");
break;
Technology news on Phys.org
Hmm...
Your removehead method looks generally right, but one question. Think about what happens when you remove the VERY LAST object in the whole linked list. What happens to "tail"?
Your addhead on the other hand contains a lot of problems. I'm just going to write in some comments noting the problems I see, let me know if I'm not clear enough:
Code:
if (head == null)
head = new Link(newData, tail); // If head is null, then won't tail also be null?
else if (head != null && tail == null) // It should never be possible for this case to be true. Head is supposed to be the first item of the list. Tail is supposed to be the last item of the list. If either head or tail is null, ever, then that implies the list is empty.
tail = head; // In other words, you just set the end of the list to be the new start of the list. Why?
head = new Link (newData, tail); // As required by the "if" statement above, tail is currently null. Is this what you want?
else
head.next = head; // Think about this: You are setting "the item after A" to be equal to "A". You just turned head into a very small linked list pointing to itself.
head = new Link (newData, head.next); // "Set the new head to be a Link object containing newData, and followed by the item AFTER the current head". Is this what you want?
I think you need to be more careful in general about thinking: What should head be pointing to? What should tail be pointing to? If at any given moment I start with the object pointed to by "head" and step forward until I hit null, which objects will I see on the way if the list is working properly?
One more thing: why *are* you keeping track of a tail pointer? Usually "tail" is something people use in conjunction with a doubly-linked list. Your list is singly-linked. And if you intend to use this linked list only as a stack, then there is no reason whatsoever to keep track of the tail.
ok, i think I know what you mean. Also, about the tail pointer, I am supposed to have it reference my last object on the stack.
I tried to change somethings around to make more sense. The problem, for example if I addHead A, then B, then C, then D. When I go to remove,the first time it removes D, but the second attempt (and third, and fourth, etc) it just tells me its removing C but doesn't actually do it. I also tried to finishish addTail and it just adds to the front... so I need to keep working on that one.
Thx for the tips btw.
here is the updated code...
if (head == null && tail == null)
tail = head;
else if (head != null && tail != null)
head.next = head;
if(head.next == null)
tail = head;
Link current;
tail = head;
else
while (head != null)
head = head.next;
tail = head;
if (head != null)
head = head.next;
tail = head;
UPDATE: Ok, I think my addHead and removeHead methods work as intended. They seem to add and remove (thx for pointing out that tail would remain in the end). Only problem I'm having now is addTail. it always seems to add to the head. Here is the code.
tail = head;
else
head = new Link(newData,head);
tail = head;
while(head != null)
head = head.next;
tail = head;
if (head != null)
head = head.next;
if (head == null)
tail = null;
Hi Grouchy,
A clause from your AddTail... consider what this code does:
Code:
	while(head != null) // Until the head pointer becomes equal to null,
		head = head.next; // Set the head pointer equal to the next item in the list.
	head = new Link(newData,head); // Set the head pointer to a new node, followed by the head pointer (which, after your last two lines will always be...?)
	tail = head; // Set the tail pointer to the head pointer
  • · Replies 19 ·
