Why does gravity not end at the event horizon?
The discussion centers on why gravitational influence does not cease at a black hole's event horizon, despite the notion that nothing can escape a black hole. It is argued that gravity, like light, cannot escape due to its propagation speed being limited by the escape velocity. The conversation also touches on the interaction of gravitons and the implications of gravitational waves, suggesting that gravity may interact with itself in a non-linear manner unlike classical electromagnetism. Additionally, questions arise about the implications of division by zero in physics, particularly regarding singularities in black holes, where current theories fail to provide answers. Overall, the complexities of gravity and its relationship with black holes and general relativity are highlighted as areas of ongoing inquiry.
okkvlt
A question that's been bugging me:
Why doesn't the gravitational influence of a black hole end abruptly at the event horizon?
Supposedly nothing can escape a black hole, so how does gravity itself escape?
Light cannot escape a black hole, and gravity travels at the speed of light. Therefore both gravity and light travel below the escape velocity. Thus, gravity cannot escape the black hole.
I suppose you could bring up the fact that photons don't interact with other photons, and then extend that to gravity by declaring that gravitons don't interact with other gravitons. But this still leaves something to be desired: how can anything escape the curvature of space-time? If gravitons arent affected by the curvature of space, then what else is there other than space that gravitons can move through?
Furthermore, the existence of gravitational waves produced by binary star systems seems to imply to me that gravity does interact with itself.
In your explanation, please use math i can understand(no tensors).
thanks.
Also, another question: How does the inverse square law manifest itself in GR? In Newtonian mechanics, its so elegant that the inverse square law is a result of the equation for the surface area of a sphere. And the inverse square law also works for electromagnetism, so I am kind of skeptical of general relativity- it just seems to muddle things up.
And what happens when division by zero enters the laws of physics?(as in a black hole where distance=0) Does the force become infinite? or is zero distance impossible?
Unlike classical electro-magnetism, GR is non-linear. So if a graviton description of gravity exists (that is still debatable), gravitons should interact with gravitons.
As for the "how does the force escape" type questions, I think you are taking the concept of a force mediated by particles too literally.
For example, virtual photons CAN escape a black hole. So if charges fall into the black hole, from the outside you can indeed tell that the black hole is charged. Similarly with gravity.
Does that help some?
It sounds like the main sticking point is the force mediated by particles description, so I'd suggest starting there if you wish to dig further.
That usually indicates a failure of the theory (or choice of parameterization). We can't say what happens at the singularity using GR, because GR can't tell us.
As I understand it, to the outside observer the black hole takes an infinite time to form, although in its own frame, the black hole forms right away. In any case, the gravity felt by the outside observer is that of the object becoming a black hole.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
  • · Replies 46 ·
  • · Replies 20 ·
  • · Replies 73 ·
  • · Replies 62 ·
  • · Replies 21 ·
