Electric fields, distance, and potential difference
The problem involves calculating the magnitude of a uniform electric field between two plates given a potential difference and distance. The subject area is electric fields and potential difference in the context of physics.
  • Exploratory, Assumption checking
  • The original poster attempts to apply the equation E = V/D but expresses confusion regarding unit conversions and the resulting calculation. Participants question the correctness of the original poster's final answer and discuss the inclusion of units.
The discussion is ongoing, with participants verifying the equation used and the calculations performed. There is no explicit consensus on the correctness of the final answer, and some participants express confusion about the expected result.
The original poster mentions a specific requirement for the answer to be in N/C, indicating a potential focus on unit conversion issues. There is also a lack of clarity regarding the expected answer, which may influence the discussion.
goWlfpack
The potential difference between the accelerating plates of a TV set is about 20 kV. If the distance between the plates is 1.0 cm, find the magnitude of the uniform electric field in the region between the plates.
V=ED so E=V/D where E is the electric field and D is the distance between the plates
I am soooo confused. I swear I am just plugging in the numbers. since kv is 1000 v and cm is 1/100th of a m i did 20,000/.01 and that was wrong. I did this because they want the answer in N/C and i thought that conversion factor was right... any suggestions?
Your equation looks right to me. What did you get for a final answer? Did you include the units in your answer?
yes the units are already written after the equation. I got 2.0*10^6. after going over everything it looks right to me...
Yes, looks right to me too. Weird.
What's the answer supposed to be?
  • · Replies 16 ·
  • · Replies 58 ·
