Calculating Distance for Throwing an Egg from a Building
  • Thread starter Thread starter veronicak5678
    Acceleration
The problem involves calculating the distance a person should be from a building when an egg is thrown downward from a height of 10.0 m with an initial velocity of 2.0 m/s. The person is moving toward the building at a speed of 1.25 m/s.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the time it takes for the egg to fall and question the initial assumptions about the time calculation. There is exploration of kinematic equations to determine the correct time of flight and the appropriate sign for gravitational acceleration.
Some participants have provided guidance on the use of kinematic equations and the importance of considering the direction of acceleration. There is an ongoing exploration of the time it takes for the egg to reach the ground, with differing interpretations of the initial conditions.
Participants are considering the effects of gravitational acceleration and its sign based on the direction of motion. There is uncertainty regarding the initial velocity and its impact on the calculations.
veronicak5678
You plan on throwing an egg at someone from the roof. You throw the egg downward at 2.0 m/s from a height of 10.0 m above the person's head. The person walks toward the building at 1.25 m/s. How far from the building should the person be when you throw it?
V= delta x/ delta t
delta t = 5 seconds
delta x =(1.25 m/s)(5 seconds)
They should be 6.25 m from the building.
Could someone please doublecheck this for me?
If the 2.0 m/s is an initial velocity, the egg would be accelerating downward and the time it takes to traverse the 10m distance would be much less than 5 seconds.
Thanks for the reply. I tried re-evaluating this using v final squared = v initial squared +2at
and v final = v initial + at
and came up with a time of 1.23 s.
Is this correct? I'm not sure if I should use -9.8 or 9.8 for the acceleration of gravity.
Since the egg is traveling in the same direction the gravitational force is acting, the acceleration will be a positive value for this case. Just be careful for future problems as direction is a key factor for the sign of the acceleration value. A way to think of it is the egg is being thrown downward therefore the acceleration will increase the velocity, so the equation should match this property. I believe you have come up with the correct time.
Gotcha. Thanks so much for your help.
  • · Replies 30 ·
