Which Happens First: Water Spills or Bottom Exposed in a Cylindrical Centrifuge?
The discussion centers on the dynamics of water in a cylindrical centrifuge with a radius of 1 meter and height of 2 meters, filled to a depth of 1 meter. As the centrifuge accelerates, the water forms a parabolic shape, and the key question is whether the water will spill out or the bottom will be exposed first. The consensus, after analysis, indicates that the bottom will be exposed first, and the solution involves applying integral calculus to derive the equation of the parabola representing the water's surface.
  • Understanding of cylindrical geometry and properties
  • Knowledge of integral calculus
  • Familiarity with parabolic equations
  • Basic principles of rotational dynamics
  • Study the derivation of parabolic equations in fluid dynamics
  • Learn about the application of integrals in calculating volumes and surface areas
  • Research the effects of rotational motion on fluid behavior
  • Explore advanced topics in calculus related to variable shapes and surfaces
Students in physics or engineering, particularly those studying fluid dynamics and rotational systems, will benefit from this discussion.
Doogan1
1. Homework Statement
A cylindrical centrifuge of raidus 1 m and height 2 m is filled with water to a depth of 1 meter. As the centrifuge accelerates, the water level rises along the wall and drops in the center; the crossection will be a parabola.
a) Find the equation of the parabola in the figure in terms of h, the depth of the water at its lowest point.
b) As the centrifuge rotates faster and faster, either water will be spilled out of the top, or the bottom of the centrifuge will be exposed. Which happens first?
2. Homework Equations
R=1
H=2m
depth of water= 1m
3. The Attempt at a Solution
I've been thinking this problem must have something to do with integrals, but i am lost in the fact that the parabola from the cross section is constantly growing. I just can't seem to find an equation for the parabola, but i have made a hypothesis that the bottom will be exposed first, based of course off of no mathmatical basis. Help desperately needed.
Welcome to PF!
Hi Doogan1! Welcome to PF! :smile:
Don't panic … questions like this are carefully written so that you can ignore the change in rotation.
Just assume that the rotation is constant, and work out the surface shape on the assumption …
i] the surface just touches the top
ii] the surface just touches the bottom. :wink:
Thx for replying and trying to help. I figured the problem out with my teacher today and basically it turned out to be just a big ol' integral.
  • · Replies 23 ·
