Special Relativity and the Lagrangian
The discussion revolves around the relationship between the Lagrangian formulation in classical mechanics, expressed as T - U, and the invariant interval in special relativity, represented by t^2 - x^2. Participants explore whether there is a deeper connection between these concepts, particularly in the context of symmetries and dynamics in physics.
  • Some participants propose that the Lagrangian form T - U might have a connection to the relativistic interval t^2 - x^2, given the associations of kinetic energy with time and potential energy with space.
  • Others argue that the form T - U is unconnected to t^2 - x^2, suggesting that any similarity is coincidental.
  • A participant mentions that T - U is not the total energy and provides an example of a Lagrangian for a vibrating string that resembles the form of the interval.
  • Another participant notes that the invariance of the interval under Lorentz transformations relates to the symmetries of special relativity and questions what transformations leave the dynamics of a specific Lagrangian unchanged.
  • One participant claims to have found a deep connection between the Lagrangian and proper time in general relativity, suggesting that the action principle leads to a minimum condition that relates to the Lagrangian form.
Participants do not reach a consensus on the connection between the Lagrangian and the relativistic interval, with multiple competing views remaining. Some assert a connection, while others maintain that no such relationship exists.
Discussions include unresolved assumptions about the nature of potential energy and its representation in the Lagrangian, as well as the implications of symmetries in special relativity and general relativity.
dx
Hi,
The invariant quantity in special relativity is [tex]t^2 - x^2[/tex] and the form of the lagrangian is [tex]T - U[/tex]. The kinetic energy T has to do with time while the potential energy U has to do with space. I was just wondering if there's some known connection here.
Rereading my post, I think maybe I didn't explain my question properly. In classical mechanics the Lagrangian has the form [tex]T - U[/tex]. In special relativity, the interval [tex]t^2 - x^2[/tex] is invariant. I've always found the specific form T - U of the Lagrangian pretty baffling, and have wondered whether there's any deeper way of looking at it. Recently I got the idea that maybe there's some connection between the relativistic interval and the Lagrangian, since the kinetic energy is associated with time and the potential energy is associated with space, like t and x in the expression for the interval. So is there any known connection between the relativistic interval and the Lagrangian?
Not as you put it. The form T-U is unconnected to the form t^2-x^2.
Because we consider potential energy to be negative, T - U is the total energy. The Lagrangian will give the same dynamics if it is rewritten,
L = T + (K-U(x))
where K is a very large constant representing all the potential energy in the system.
I think the similarity in form to x2-t2 is coincidental.
Mentz,
T - U is not the total energy, I don't understand why you think that. Also, consider the Lagrangian of a string, where the particles are vibrating transversely. In appropriate units, it has the form
[tex]L = \frac{1}{2} \int (\frac{dy}{dt})^2 - (\frac{dy}{dx})^2 dx[/tex].
where the integrand is of the form [tex](time derivate)^2 - (space derivative)^2[/tex], which also suggests an analogy with [tex]t^2 - x^2[/tex].
And yes I know [tex]L = T - U + K[/tex] where K is a constant will give the same dynamics, but notice that [tex]t^2 - x^2 + K[/tex] is also an invariant.
Dx,
yes, I was thinking of the Hamiltonian H = T + U for the SHO. Whoops.
To get back to your question. The invariance of x2-t2 under Lorentz transformations tells us about the symmetry of SR. If the form T - U is significant it will be related to a symmetry.
So, what transformations leave the dynamics of
unchanged ?
M
I don't know exactly, but there is some sort of connection.
From the Lagrangian we get the Euler-Lagrange equations, which describe geodesic motion. In relativity, free particles and free photons move on geodesics, trajectories of extremal arc length, with arc length given by ds2.
See the discussion beginning at 3.4.3:
John Baez, Blair Smith and Derek Wise, Lectures on Classical Mechanics.
http://math.ucr.edu/home/baez/classical/texfiles/2005/book/classical.pdf
I started this thread a long time ago, and the issue wasn't resolved to my satisfaction at that time. I have since found the relationship I was looking for. It is essentially an elaboration of what atyy said. I thought I would post it in case anyone is interested. The question was whether there was any relationship between the Lagrangian expression [itex]L = T - U[/itex] and the proper time [itex]s^2 = t^2 - x^2[/itex], since they look formally similar and also the relationship between T and t, and U and x, is analogous. It turns out that there is indeed a very deep connection between the two, involving general relativity!
The law of motion in gravitational fields in general relativity says that the proper time along the correct path [itex]\int ds[/itex] is maximum. For a particle moving vertically on the surface of the earth, choose an arbitrary path [tex]h(t)[/tex]. General relativity says that the relative rate of a clock is higher if the clock is higher in the gravitational field by an amount [itex]gh/c^2[/itex]. If the clock is moving, then there is an additional change in the relative rate due to special relativity which is approximately [itex]-v^2/2c^2[/itex]. Therefore, the condition that the proper time is maximum will be
[tex]\int ( gh - v^2/2 )dt = max.[/tex]​
If you multiply this by [itex]-m[/itex], you get
[tex]\int ( mv^2/2 - mgh )dt = min,[/tex]​
which is exactly the condition that the the action [itex]\int (T - U) dt[/itex] is a minimum. I found this in "The Feynman Lectures" (vol. II), if you want more details.
