Voltage controlled dependent current source
The discussion revolves around solving for the voltage drop across a voltage-dependent current source in a circuit that includes an independent current source and various resistors in parallel. The focus is on the application of circuit analysis techniques to determine this voltage drop.
  • Technical explanation, Homework-related, Mathematical reasoning
  • One participant inquires about the method to solve for the voltage drop across a voltage-dependent current source when it is in parallel with other resistors and an independent current source.
  • Another participant suggests using circuit analysis methods such as nodal analysis or mesh analysis, while emphasizing the validity of Kirchhoff's Current Law (KCL) and Kirchhoff's Voltage Law (KVL) without knowing the specifics of the circuit.
  • A later reply advises simplifying the circuit by combining the parallel resistors into an equivalent resistor and notes that the potential drop across the resistor can be identified as VA, suggesting that this would lead to finding VA.
Participants generally agree on the applicability of circuit analysis techniques but do not reach a consensus on the specific approach to take without further details about the circuit.
The discussion lacks a visual representation of the circuit, which may limit the clarity of the analysis and the proposed solutions. There are also unresolved assumptions regarding the configuration of the circuit elements.
Students or individuals studying circuit analysis, particularly those dealing with dependent sources and parallel resistor configurations.
goldfronts1
I had a question. When you have a circuit with a independent current source and a voltage dependent current source. And the dependent current source is dependent on the Voltage drop across the independent current source. How do I solve for this voltage drop when the currents are in parallel with other resistor values?
Do I use KCL?
thanks
You use whatever tools are available to you, such as nodal analysis, mesh analysis. But I can't tell you any more than that since I don't know what your circuit looks like. KCL and KVL is valid everywere, though. Do you have a picture of the circuit?
here is the circuit thanks
Now the first thing you should do would be to simplify the circuit. Combine all those resistors in parallel into one equivalent resistor. Then you have two current sources in parallel with the Req. It can be seen then that the potential drop across the resistor is also VA. From here you should be able to find VA.
  • · Replies 19 ·
  • · Replies 44 ·
  • · Replies 81 ·
9K
9K
