Double integration calculation
The discussion focuses on calculating the volume of a sphere using double integrals in polar coordinates. The integral presented is \int^{2\pi}_{0} \int ^{a}_{0} \sqrt{(a-r^{2})} rdrd\theta, which yields half the expected volume due to the integration limits. To compute the full volume, the inner integral should range from -a to +a, accounting for both hemispheres. The correct volume formula derived is (4/3)*\pi*R^3 for the sphere and 4*\pi*R^2 for the surface area.
  • Understanding of double integrals and polar coordinates
  • Familiarity with volume and surface area calculations of geometric shapes
  • Knowledge of integral calculus, specifically in three dimensions
  • Ability to manipulate and evaluate integrals involving trigonometric functions
  • Study the derivation of the volume of a sphere using triple integrals
  • Learn about the Jacobian in polar coordinates for volume calculations
  • Explore the application of spherical coordinates in multivariable calculus
  • Investigate the relationship between surface area and volume for various geometric shapes
Students and professionals in mathematics, physics, and engineering who are involved in geometric calculations, particularly those focusing on volume and surface area integrals.
Fys
I want to calculate the integral of a sphere with radius a using double integrals
I have [tex]z^2+y^2+x^2=a[/tex] and I plug this in my equation and integrate in polar coördinates
Now i have [tex]\int^{2\pi}_{0} \int ^{a}_{0} \sqrt{(a-r^{2})} rdrd\theta[/tex]
But why do I need to multiply my integral with 2 (because i get half the answer I expect).
Can someone explain this please?
thanks guys
I assume that it is the volume of the sphere which you wish to calculate.
In polar coordinates, the volume element is dr * (r * dtheta) * {r * sin(theta) * dphi}.
Or r2 *dr * sin(theta) * dtheta * dphi.
This must be integrated for r between 0 (the midpoint) and R (the surface), for theta between 0 (the north pole) and pi (the south pole) and phi between zero (setting out from some meridian eastward) and 2*pi (arriving at the same meridian from the west).
The integrals can be split.
Integrating r2dr between 0 and R, we get (1/3)R3.
Integrating sin(theta) dtheta between 0 and pi we get 1 - (-1) = 2.
Integrating dphi between 0 and 2*pi, we get 2*pi.
Multiplying, we get (4/3)*pi*R3.
If you want the surface of the sphere, you use the surface element (R*dtheta) *{R*sin(theta)*dphi}, just do the theta and phi integration, and get 4*pi*R2.
Looking at your own method, I get the impression that you are only calculating the volume of the northern hemisphere. The inner integral should run fron -a to +a, not from 0 to +a.
  • · Replies 19 ·
  • · Replies 105 ·
13K
  • · Replies 21 ·
