HELP A question on Kinematics in 2D & 3D?
  • Thread starter Thread starter Kudo Shinichi
    2d 3d Kinematics
The discussion revolves around a kinematics problem involving projectile motion on a slope. The original poster seeks to determine the distance along a hill where a bullet will land, given various parameters such as the angle of the hill, the angle of the gun, and the muzzle velocity.
  • Participants discuss separating the problem into two one-dimensional equations for the x and y axes. There are questions about the conditions at the point of impact and how to relate the variables in the equations.
Some participants have offered guidance on how to approach the problem by suggesting the use of conditions at the point of impact and the relationship between the x and y equations. Multiple interpretations of the setup are being explored, particularly regarding the axes and the variables involved.
The original poster expresses uncertainty about the values of several parameters, indicating a potential lack of information needed to proceed with the problem.
Kudo Shinichi
HELP! A question on Kinematics in 2D & 3D?
A gun is placed at the base of a hill whose slope makes an angle alpha with the horizontal. If the gun is set at an angle theta with the horizontal and has a muzzle velocity Vo, find the distance, measured along the hill, at which the bullet will fall.
I know that I need to separate this question into two equations/ two 1D problems (x-axis and y axis)
Velocity for x = Vo* cos(Θ-α) - g * t * sin(α)
X = Xo + Vo * t * cos(Θ-α) - 0.5 * g * t^2 * sin(α)
Velocity for y = Vo* sin(Θ-α) - g * t * cos(α)
Y = Yo + Vo * t * sin(Θ-α) - 0.5 * g * t^2 * cos(α)
But how can i figure out Vo, Θ, α, Xo, t and Yo
Please help me.
Seems you've set your axes up so that the x-axis runs along the slope. What condition occurs at the point of impact that you can use. That is, what will the value of the y-axis be?
Do you mean set subsitute one of the variable in y equation from x equation?
Yes. What will the y position be with the coordinates you chose when the ball lands? You can then get an expression for the flight time and sub it into the x equation which will give you the distance when t is the total flight time.
  • · Replies 38 ·
