(C++) How would I display a value rounded to the nearest integer?
  • Context: C/C++
  • Thread starter Thread starter soul5
    Integer Value
The discussion revolves around how to round a floating-point number to the nearest integer in C++. Participants explore various methods and provide examples of code snippets to achieve this rounding.
  • One participant suggests using a simple cast with an adjustment, such as (int)(3.5 + 0.5), to round a number.
  • Another participant emphasizes the need to input the number as a float rather than an int for proper rounding.
  • Multiple methods for rounding are proposed, including truncation, rounding to +infinity, and rounding away from zero, with code examples provided for each approach.
  • A later reply mentions the use of std::round from C++11 as a straightforward option for rounding.
  • There is a caution against using direct equality comparisons with floating-point numbers due to precision issues.
  • One participant expresses that they find a previous answer sufficient and simple, indicating a preference for simplicity in solutions.
Participants generally agree on the necessity of using floating-point variables for accurate rounding, but there are differing opinions on the best method to implement the rounding, with no consensus on a single approach.
Some methods discussed may depend on specific definitions of rounding (e.g., rounding to even), and there are unresolved considerations regarding the handling of floating-point precision.
soul5
Like for example
Prompting message reads.
"Please enter a positive value"
Example:
Please enter a positive value: 234.7
Rounded to the nearest integer the number is: 235
Please enter a positive value: 10.3
Rounded to the nearest integer the number is: 10
What I have
int num;
count<< "Please enter a positive value";
cin>> num;
count<< num << endl;
The problem is that doesn't round the number to the nearest interger so what would I do to round it?
Technology news on Phys.org
soul5 said:
Like for example
Example:
What I have
int num;
cin>> num;
(int) (3.5+0.5)
rootX said:
(int) (3.5+0.5)
Dude that's not it.
rootX gave a correct example of the calculation needed. You need to input as a float, not an int, then convert to an int by rounding as in rootX's suggestion.
It does help if num is a floating point variable, rather than an int.
Round to zero (truncation)
Code:
int rounded_num = static_cast<int>(num);
Round to +infinity
Code:
int rounded_num = std::floor(num + 0.5);
Round away from zero
Code:
int rounded_num = (num < 0.0)
    ? ((std::floor(num) == num - 0.5) ? std::floor(num) : std::floor(num + 0.5))
    : std::floor(num + 0.5);
Really shouldn't do direct == with floating points, but that's another subject.
Or in C++0x:
Code:
int rounded_num = std::round(num);
Round to even
Um, have fun...
Code:
Round to +infinity
Code:
Code:
Or in C++0x:
Code:
Round to even
Um, have fun...
very insteresting, but I think rootx's answer is enough and simple.
13K
