Tension between 2 blocks and friction.
The discussion revolves around a problem involving two blocks connected by a string, being pulled across a surface with friction. The participants are tasked with finding the tension in the string given the masses of the blocks, the applied force, and the coefficient of friction.
  • Mixed
  • Participants discuss the calculation of frictional forces and the application of Newton's laws. There are attempts to clarify the pulling forces on each block and the overall acceleration. Questions arise about the accuracy of the frictional force values and the method of summing forces.
The conversation reflects a mix of attempts to clarify calculations and methods, with some participants expressing uncertainty about their reasoning. While one participant claims to have resolved the problem, others are still exploring their understanding of the forces involved.
There are indications of confusion regarding the correct values for frictional forces and the acceleration of the blocks. Participants are also grappling with the implications of their calculations and the necessity of drawing free body diagrams.
CaptainSFS
A block of mass m1 = 2 kg and a block of mass m2 = 3 kg are tied together and are pulled from rest across the floor by a force of P = 25 N. The coefficient of friction of the blocks with the floor is µ = 0.14.
I found the acceleration to be 3.6266 m/s2.
I need to find the tension in the string between the blocks.
F=ma and Ff=u(mg)
The total frictional force is 6.867 N. m1 has a frictional force of 2.7468 i think, and m2 has a frictional force of 6.7596 i think. I think the pulling force on m1 is 7.2532 N. I mean, i tried creating different summations of the forces, but I don't know what I'm doing wrong. I'm sure I could figure it out, but I need to at least know how to add the forces up in each direction. Thanks so much.
Good. You should round it off though to 3.6
yes
yes
where did you get this?
how did you arrive at this?
Draw a Free Body Diagram of block 1 (isolate it) , and examine the forces acting on it to solve for T using Newton 2. What is the acceleration of block 1?
okay, I typed the wrong number in for m2's frictional force. I meant to type in 4.1202 N. I arrived at m1's pulling force by (2)(3.6) = F. Right, I thought I tried creating a FBD but for some reason I'm doing something wrong. Is the acceleration on block m1 = 2.25 m/s2? At this point I am not sure what I am supposed to do.
EDIT: wait, doesn't the acceleration have to be equal to 3.6m/s2?
Hey, if someone could help me. I'm really stuck on this one, I just think I've dug myself a deeper hole trying to work this out. I would really appreciate any more help.
EDIT: I solved it. it's 10 N...
  • · Replies 17 ·
