Finding the locus of points for complex analysis
The discussion focuses on finding the locus of points \( z \) that satisfy two specific equations in complex analysis: \( |z-i|=Re(z) \) and \( |z-1|^2=|z+1|^2+6 \). The first equation can be interpreted geometrically as the distance from the point \( z \) to \( i \) being equal to the distance from \( z \) to the y-axis. The second equation involves manipulating distances in the complex plane, leading to a geometric interpretation that can be simplified by substituting \( z \) with \( x + iy \).
  • Understanding of complex numbers and their representation in the form \( z = x + iy \)
  • Familiarity with geometric interpretations of complex equations
  • Knowledge of the properties of absolute values in complex analysis
  • Ability to manipulate equations algebraically, including squaring both sides
  • Explore the geometric interpretation of complex equations using the cosine formula for triangles
  • Learn how to convert complex equations into Cartesian coordinates for easier analysis
  • Study the properties of loci in the complex plane, particularly circles and lines
  • Investigate the implications of squaring both sides of complex equations and its effects on the solutions
Students and educators in mathematics, particularly those studying complex analysis, as well as anyone interested in the geometric interpretation of complex equations.
calculuskatie
I think this should probably be easy, but I am stuck. My book is of no help.
Find and describe the locus of points z satisfying the given equations:
1. |z-i|=Re z
2. |z-1|^2 =|z+1|^2 +6
I am thinking for the 1st one that I have to square both sides, but then what? What happens to Re z?
For the second one, I am totally lost. My first instinct would be to take the square root of both sides...and then...?
Thanks to all.
Welcome to PF!
1. |z-i|=Re z
Hi calculuskatie! Welcome to PF! :smile:
Hint: |z - a| is just the distance from z to a.
So just use geometry (including the cosine formula for triangles).
How would you describe those two equations in geometry? :smile:
Have you tried replacing z by x+ iy so that each equation becomes an equation in x, y?
That should make the curves easier to recognize.
For example, if z= x+ iy, then z- i= x+iy- i= x+ (y-1)i and so [itex]|z-i|= |x+ (y-1)i|= \sqrt{(x+ (y-1)i)(x- (y-1)i)}[/itex] (because [itex]|z|= \sqrt{z \overline{z}}[/itex])
[itex]= \sqrt{x^2- (y-1)^2}[/itex] and, of course, Re(z)= x. What kind of graph does [itex]\sqrt{x^2- (y-1)^2}= x[/itex] give? (Try squaring both sides.)
Another, more geometric way to do this is to note that |z- i| is the distance from the point z, in the complex plane, to the point i. Re(z), on the other hand, is the distance from z to the y-axis. What kind of figure has distance from a point on the graph to a point equal to the distance from that point to a line?
