Why is hex meshing preferred over tet meshing in CFD?
  • Thread starter Thread starter mahaesh
    Cfd Meshing
The discussion revolves around the preference for hexagonal meshing over tetrahedral meshing in computational fluid dynamics (CFD), particularly focusing on the implications for accuracy, computational efficiency, and the influence of mesh structure on numerical methods.
  • Some participants suggest that hex meshes are preferred due to their compatibility with high-order numerical schemes, which require structured meshes.
  • Others argue that hex elements typically provide better accuracy due to their shape and interpolation properties, as well as better control over degrees-of-freedom in the model.
  • One participant contends that no grid type inherently has better accuracy than another, noting that tetrahedral meshes can outperform hex meshes in certain scenarios, particularly with localized refinement.
  • There is a discussion on the concept of order of accuracy, with one participant explaining how higher-order schemes can significantly reduce error compared to first-order schemes, especially in applications like aeroacoustics.
  • Another participant expresses doubt about the assertion that grid elements should always align with flow direction, questioning whether hex meshes are always superior in that context.
  • Some participants acknowledge that the choice between hex and tet meshes is case-dependent, emphasizing that the effectiveness of a mesh type can vary based on specific conditions and requirements.
Participants do not reach a consensus on the superiority of hex meshes over tet meshes. Multiple competing views remain regarding the accuracy and efficiency of different mesh types, with some arguing for the advantages of hex meshes while others highlight the potential benefits of tetrahedral meshes in certain contexts.
The discussion reflects varying assumptions about the relationship between mesh type and accuracy, as well as the conditions under which each type may be preferable. There are unresolved nuances regarding the definitions of accuracy and the impact of mesh structure on computational outcomes.
mahaesh
Hi everyone!
Can you explain me Why always hex mesh is preffered instead of tet mesh if hex mesh is possible in perticular geometry? give brief explanation as flux point of view.
For the stuff that I've done, a hex is sometimes needed if high-order schemes are being used, as a structured mesh is needed.
Not even trying to provide a complete answer, but would say that hex element types have typically better "accuracy" (with the type and degree of interpolation they possesses as well as element shape (aspect ratio, distortion etc.) related issues, if you perform for example error estimation) for solving most PDEs. In addition, structured/mapped/hex meshes typically have better "quality" (could call it distribution, position (and just overall control) of degrees-of-freedom in the model). There is a whole lot more to be said about this if interested or want to read more.
I would have to disagree with you Perennial, maybe it's mostly semantics, but either way. I would argue that no grid type has better "accuracy" than another type. Tets can give better answers than hex meshes, and vice versa. I will agree that using structured hex meshes give you ability to use high order of accuracy; but that concept is not directly related to the actual accuracy. Using first-order tet elements with localized bunching can give you a better answer in less computation time than hexes. Again though, it's on a case by case basis.
However, in the field of aeroacoustics, I would say that structured hexes are a necessity, when possible. This goes back to the concept of order of accuracy. Order of accuracy is defined as the rate at which the error decreases with decreasing mesh spacing. The error can decrease exponentially though for higher order schemes. For example, when halfing the grid spacing, for a single order scheme, the error decreasing by:
[tex]\epsilon = (2)^1 = 2[/tex]
Where 2 is the grid density factor, and 1 is the order of the scheme being used. If I were to use a 6th order DRP scheme, I would expect the error to drop by:
[tex]\epsilon = (2)^6 = 64[/tex]
Now that's not to say that a higher order scheme will always out perform a low order scheme, because that's not the case. In fact, at large grid spacing, one can show that a low order scheme actually provides a better solution with less error. However, if one needs very very high accuracy (as in the case of aeroacoustics), then one can easily see that in order to get the desired accuracy from a first-order scheme, the grid density will need to become ridiculous; whereas there will be a crossing point where the high-order scheme becomes less computationally heavy.
IMHO, CFD is still very much a black or grey art/practice, where the user really needs to understand much of what's going on behind the scenes in order to determine how much to believe the answer.
Thanks "minger" for your answer
but again I have some doubt In CFD It is always criteria that your grid elements(hex/tet) should be along flow direction then I think that Hex are always better than tet mesh.
I'd think you're not really disagreeing :wink: , since the "accuracy" especially as a loose definition like being used in this discussion is a property dependent on so many things. Grid type itself doesn't lead a solution being better than some other, but what I'm arguing is that "typically" if we don't dig deeper then a hex design is "as a rule somewhat preferable" (such rule may not have much generality however for a particular appl, that "grey area" of things). In many cases a tet one will do a better job and in many cases a hex one, there are no general rules in this sense since "accuracy" is not a property directly related to grid type. Need to fix more things to get there. As you mention, it's often most interesting how a better solution can be attained by purposely decreasing the "accuracy" of certain features in your mesh/model.
Definitely, that's kinda why I said it's mostly semantics.
13K
47K
