Need Help - velocity measuring problem
  • Thread starter Thread starter Fisics Noob
    Measuring Velocity
The discussion revolves around an experiment related to projectile motion, focusing on measuring initial velocity while varying mass, launch angle, and initial velocity to achieve maximum range. The original poster seeks methods to measure initial velocity in their experimental setup involving a mass rolling down a ramp and projecting off a jump.
  • Participants discuss using conservation of energy to calculate initial velocity, considering potential energy and kinetic energy relationships. Questions arise about the effects of friction and air resistance on the measurements.
Some participants have provided guidance on using energy conservation equations to derive initial velocity. The discussion includes various interpretations of the variables involved and acknowledges the independence of initial velocity from mass in the derived equations.
The original poster aims to neglect air resistance and friction in their calculations, and the expected distance of the projectile is relatively short, which may influence the dynamics of the experiment.
Fisics Noob
Hey i am doing an experiment for a school physics assignment on projectile motion. I have three variables which i want to change so i can see how i can obtain a maximum range (distance). I have chosen mass of projectile, angle of launch and initial velocity of mass as my three variable.
My problem is that i have not been able to come up with a way to measure the initial velocity. My experimental setup at the moment is; small mass, rolls down ramp to a small inclined "jump" and then gets projected out and travels a certain distance. Is there some device that will help me measure the initial velocity or can i calculate it by conservation of energy (PEg to KE).
Any input will be awesome
TY
Conservation of energy definitely makes sense--subtract the potential energy at the height of the ramp from the initial potential energy at the height of the decline and you will get your kinetic energy, and then you can solve for the velocity, v. Frictional forces are likely to have some effect, so you could try including those in your calculations.
Are you familiar with the equation that gives the range of a projectile (without air resistance)?
http://en.wikipedia.org/wiki/Range_of_a_projectile
If not, do your experiment first, and then interpret your results in regards to the variables that appear in the equation. Good luck with the experiment.
Thx that is really helpful. Just talking about other variables, i am hoping to include things like air resistance and friction as negligible. i am estimating to get a distance of about 20cm tops so the mass will not be airborne for very long.
You said using cons of energy;
PEg = mgh
KE = 1/2mv^2
So;
KE (when leaving ramp) = PEg (at drop height) - PEg (when leaving ramp)
1/2 mv^2 = mgh1 - mgh2
v^2 = 2(mgh1 - mgh2)/m
Then square root and you should have your initial velocity assuming that all potential energy is converted into kinetic and there is no loss of energy to friction or air resistance.
Does that look right?
Yes, your equations look good. Great job.
Also, notice that the initial velocity is independent of mass ("m" cancels out of your equations).
  • · Replies 16 ·
  • · Replies 60 ·
