Find acceleration of the mass immidiately after rope is cut
The problem involves a 20 kg mass suspended by two ropes, with one rope positioned horizontally and the other at an angle of 30 degrees. The discussion centers around calculating the tension in each rope while the mass is at rest and determining the acceleration of the mass immediately after one of the ropes is cut.
  • Participants discuss the tension in rope 2 and its components, questioning how to relate the vertical and horizontal components of tension. There are attempts to clarify the setup of the ropes and their angles, as well as the implications of cutting one of the ropes on the mass's acceleration.
The discussion is ongoing, with participants exploring different interpretations of the tension components and their relationships. Some guidance has been offered regarding the calculations of tension, but there is no explicit consensus on the final values or the approach to finding the acceleration after the rope is cut.
Participants express confusion regarding the components of tension and the overall setup of the problem, indicating that the professor's explanations may have been unclear. There is a recognition of the need for clarity in understanding the forces at play.
veronicak5678
A 20 kg mass is suspended by two ropes. Rope 1 goes to the wall horizonatlly from the left side of the mass. Rope 2 goes from the top right corner of the mass to the wall at an angle of 30 degrees from the horizontal top of the mass.
a- If the mass is at rest, what is the tension force in rope 2?
b- determine the tension in rope 1.
c- Find acceleration of the mass immidiately after rope 1 is cut.
EF = ma
1) T2y = w
T = w / sin 30 = mg / sin 30
= 392 N
2) ?
If I have done part 1 correctly, it seems like the tension in rope 1 would be 0?
EF = ma
1) T2y = w
= 392 N
2) ?
If I have the picture correctly there is a rope on each side pulling correct?
While the net horizontal forces may be 0, there is Tension in each.
Yes, there is a rope on each side, but rope 1 is halfway down the left side and pulled straight out, horizontally, to the wall. Rope 2 is coming from the right top corner of the mass and pulling to the wall diagonally. The angle of 30 is measured from the horizontal level of the top of the mass to the rope 2. I hope that makes sense. Wish I had a scanner!
veronicak5678 said:
Yes, there is a rope on each side, but rope 1 is halfway down the left side and pulled straight out, horizontally, to the wall. Rope 2 is coming from the right top corner of the mass and pulling to the wall diagonally. The angle of 30 is measured from the top of the mass to the rope 2. Hope that makes sense. Wish I had a scanner!
I think I have it.
If you look at the Tension of the angled rope it has 2 components x and y.
You know the y component must be m*g because that's all there is holding it up. The Tension then by dividing sin30 is 2*m*g.
So the horizontal component is 2*m*g*cos30 = (.866)*2*m*g
and the vertical of course is (1/2)*2*m*g = m*g.
So the horizontal Tension of one must equal the horizontal Tension of the other.
Why is the horizontal 2*m*g*cos30?
I get as far as T2y = 392 N. Isn't that independent of T2x?
You know that because there is no other vertical force component, ALL of the weight of the block MUST be carried by the vertical component.
Doesn't that translate at 30 degrees to the Horizontal the Tension in the rope as being m*g/.5 = 2*m*g?
The Tension vector is the Vector sum of the 2 components.
OK. So how do I state the total tension in rope 2? Add the components together?
Wait a minute. You already know the Total Tension. (You gave it already in your first post.) And you know the vertical component of the tension (Ty = m*g). So to find the horizontal component, that's cosθ * T2 = Cosθ *(2mg) = Tx
I thought the 392N was the tension in just the y component of rope 2. Is that wrong?
That looks like the total Tension.
M*g = 20 *9.8 = 196N is the Ty
Oh! OK, I see what I was doing. My notes for this class are a mess because the professor rushes through everything. You've explained more to me today than he has all week. Thanks again.
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 25 ·
