What Angle of Incidence Causes Total Reflection of X-rays in Calcite?
The discussion revolves around determining the angle of incidence that causes total reflection of X-rays in calcite, specifically focusing on the refractive index for X-rays and the application of relevant optical principles.
  • The original poster attempts to apply Bragg's Law to find the angle of incidence but questions whether this approach is sufficient. Participants discuss the correct application of refractive index in the context of total internal reflection and raise questions about the critical angle and the role of wavelength.
Participants are exploring the correct equations related to refractive index and total internal reflection. Some guidance has been offered regarding the critical angle, and there is an ongoing inquiry into the properties of X-rays in air.
There is uncertainty regarding the refractive index of X-rays in air, and the original poster is seeking clarification on the relevance of wavelength in this context.
Quelsita
Problem:
The index of refraction for x-rays of wavelength 0.708A incident on calcite is 1-1.85E-6. What angle of incidence will give total reflection of such X rays?
Using Bagg's Law: n(lambda)=2asin(theta), I get and angle of -45.07 degrees.
Is this all that is required of the problem...is it that simple?
Thanks.
That's the wrong "n".
Bragg's law: n = any integer
But here n is the refractive index, not an integer. So Bragg's law doesn't apply.
What equation in optics deals with refractive index and angle of incidence? You might also look into "total internal reflection"
OK, so with total internal reflection since we are looking for and angle that gives total reflection, so we want an angle greater than the critical angle, and since this means that (n1/n2) would be greater than 1, we cannot use Snell's Law: n1sin(theta1)=n2sin(theata2).
But if we let theata2=90, then we can solve for the critical angle:
thetacrit=arcsine(n1/n2)
-Is this correct?
-How does the wavelength of the X-ray apply?
Your equation is correct.
The wavelength doesn't apply.
Ok. So is the second medium just air where n2=1?
Ah, good question. Not sure what n is for x-rays in air. For optical wavelengths it's 1.0003.
But yes, the second medium is air.
