Calculating the Critical Distance for Spaceship Gravity: A Scientific Approach
  • Thread starter Thread starter brookbj
    Gravity Spaceship
The discussion revolves around calculating the critical distance at which the gravitational pull of the moon on a spaceship exceeds that of the Earth. The context involves concepts from gravitational physics, specifically Newton's Law of Universal Gravitation.
  • Participants discuss the mathematical principles governing gravitational forces and express uncertainty regarding the necessary values for mass and distance. There are attempts to set up the problem algebraically using variables for the distances and masses involved.
The conversation is ongoing, with participants exploring different interpretations of the problem setup. Some guidance has been offered regarding how to express the gravitational forces algebraically, although there is no consensus on a complete method yet.
Participants note the absence of specific numerical values for the masses and distances, which affects their ability to reach a numerical solution. The discussion also emphasizes the need to ignore other gravitational influences, such as that of the sun.
brookbj
Hey, I don't know how to go about and answer this question
A spaceship is launched and starts moving directly towards the moon. At what distance from the Earth will the pull of the moon, on the spaceship, exceed the pull of the Earth? Ignore the effect of the sun in this calculation.
can somebody push me in the right direction.
thanks
okay. First of all, what is the mathematical law that determines how gravitation works? In other words, the equation that tells you, given two masses and the distance between them, how much gravitational force they'll exert upon each other?
Hey
I know Newton's Law of Universal Gravitation, but I am not given masses or distance from the Earth to the moon or the shuttle.
That doesn't mean you can't do the problem. It just means you won't get a numerical answer. You could still set up the problem and get an algebraic answer that is *expressed in terms of* those constants you mentioned.
Example. Let the earth-moon distance be R. Let the shuttle to Earth distance be r (a variable. Then the shuttle moon distance is R - r.
Let [itex]M_e[/itex] be the mass of the earth, [itex]M_m[/itex] the mass of the moon, and m the mass of the spacecraft . Now can you do the problem?
Is it just,
GMeMm/R2 = GMmMs/(R-r)2
thanks, this question is killing me
close. the left hand side is the force between the Earth and the moon, which is not what you want.
you want:
force of Earth on spaceship = force of moon on spaceship
Thanks, for your help!
  • · Replies 65 ·
14K
  • · Replies 21 ·
