| Thread Closed |
Use either trigonometry or components to find displacement |
Share Thread | Thread Tools |
| Sep26-08, 06:38 PM | #1 |
Bob walks 160 m south, then jogs 630 m southwest, then walks 160 m in a direction 32degrees east of north. a) Use either trigonometry or components to find the displacement that will return Bob to his starting point by the most direct route. Give your answer as a distance. b)Find the direction of the displacement that will return Bob to his starting point by the most direct route. 2. Relevant equations Not sure what to use. 3. The attempt at a solution I'm not even sure where to begin, even some hints to tell me how to start would be very useful! a) 60 + 630(cos45+sin45) + 160(cos32,sin32) 60 + 630(0.71 + 0.71) + 160(0.848 + 0.5299) 60 + 447.3 + 447.3 + 135.688 + 84.787 642.98 + 533.087 642.98^2 + 533.087^2 413423.28 + 284181.83 697605 take root = 835.22 |
| Sep26-08, 11:21 PM | #2 |
Draw a picture of the displacement vectors. Bob can only move in two dimensions (a plane), so determine the x- and y-components of each vector. Now add the individual components together and you get Bob's net displacement from his initial position. It appears that you did this but I can't tell what the x- and y-components are from your notation. Also I see a 60 as the first time in your work, but not in the problem statement; should it be 160?
The most direct route is straight line, so for part a) apply the Pythagorean theorem to your net x- and y-components and take the square root to get the distance. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Use either trigonometry or components to find displacement
| trigonometry question find range | Precalculus Mathematics Homework | 7 | ||
| Determining displacement using components | Introductory Physics Homework | 4 | ||
| Crane Problem: Find Horizontal and Vertical Components | Introductory Physics Homework | 4 | ||
| help! how do i find displacement of two vectors?! | Introductory Physics Homework | 10 | ||
