| New Reply |
How can water have a molarity if theres no diff b/w solute and solvent? |
Share Thread | Thread Tools |
| Sep26-08, 10:12 PM | #1 |
mental block about this please help.
molarity is mols or a substance per Liter of a solution right? that is, mols of the solute in litres of solution. 1. What is the solution? 2. if its water, then how can you say water has a molarity? |
| Sep27-08, 03:27 AM | #2 |
Admin
Don't think in terms of solution - ie separate solvent and solute. Concentration is just amount per liter, not per liter of water. Thus you have 55.55 moles of water per liter.
| Sep27-08, 06:37 AM | #3 |
Because molarity is how much stuff you have in a certain amount of volume. It doesn't matter if it is water or an HCl solution.
| Sep27-08, 10:06 AM | #4 |
So that means that compounds dont necessarily have set molarities right?
for ex, H20 always has mass of 16 + 1 + 1 = 18, and 1 mole is always 18g, but its molarity depends on how many liters of volume 1 mole is contaained in, is that right? If yes, then why is water said to be 55.5M ?? |
| Sep27-08, 07:03 PM | #5 |
Mentor
| Sep28-08, 04:06 AM | #6 |
Admin
To be exact, molarity of pure water is 1000/18.02 = 55.51
However, in the 1M solution of acetic acid there is only 946.9 g of water per liter, so its molarity in such solution will be 846.85/18.02 = 52.56 |
| May6-10, 08:22 AM | #7 |
but u did 1000/18.02 how? |
| May6-10, 08:26 AM | #8 |
Admin
What is mass of 1L of water?
How many moles in that mass? -- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Jul15-11, 08:37 AM | #9 |
Let me breakdown:
Re: (1L = 1000 cm^3) water has an approximate density of 1g/cm^3 (temperature dependent) Therefore, 1000 cm of pure water has an approximate mass of 1000g Mass of 1 mole of water = 18.02 g Hence, no. of moles water in 1000 cm^3 of water = Total mass/mass of 1 mole = 1000 g/18.02g per mole = 55.55 moles |
| New Reply |
| Thread Tools | |
Similar Threads for: How can water have a molarity if theres no diff b/w solute and solvent?
| Solvent and UV/V spec | Chemistry | 4 | ||
| Determining which Nonpolar Solute most likely to be soluble in nonpolar solvent | Biology, Chemistry & Other Homework | 1 | ||
| Solvent washing | Chemistry | 13 | ||
| how can I solvent collagen? | Biology | 4 | ||
| Molar Mass of Unknown Solute and Mole Fraction of Gases | Biology, Chemistry & Other Homework | 7 | ||
