Solving the Roller Coaster Speed Problem: A Max Speed of 20
The discussion centers on deriving the speed of a roller coaster car described by the trajectory equation r = At(xhat) + A(t^3 - 6t^2)(y hat). The derived speed expression is v = A * √[1 + 9t^2 * (t-4)^2]. To comply with safety regulations, the maximum speed must not exceed 20, leading to the conclusion that the maximum value of the constant A is determined by the equation vmax = A * √[145]. The participants explore methods to find the maximum speed, including evaluating the derivative of the speed function.
  • Understanding of calculus, specifically derivatives and optimization
  • Familiarity with vector notation and trajectory equations
  • Knowledge of roller coaster physics and safety regulations
  • Ability to manipulate algebraic expressions and solve for variables
  • Study the principles of optimization in calculus, focusing on finding maxima and minima
  • Learn about the application of derivatives in physics, particularly in motion analysis
  • Explore safety regulations in amusement park design and their impact on engineering
  • Investigate the role of parametric equations in modeling physical systems
Students in physics and engineering, particularly those studying dynamics and motion, as well as professionals involved in amusement park design and safety compliance.
theowne
A car in a roller coaster moves along a track that consists of a sequence of ups and downs. Let the x-axis be parallel to the ground and the positive y-axis point upward. In the time interval from t=0 to t=4 s, the trajectory of the car along a certain section of the track is given by
where A is a positive dimensionless constant.
A) Derive a general expression for the speed v of the car.
The roller coaster is designed according to safety regulations that prohibit the speed of the car from exceeding 20. Find the maximum value of A allowed by these regulations.
I think I can do the first part properly. I found the derivative of the xhat equation and the y hat equation, and then found the magnitude of speed using c^2 = a^2 + b^2 of the derivatives, which comes out to
v = sqrt [A^2 + (A (3t^2 - 12t))^2]
or simplified
v = A * sqrt[1 + 9t^2 * (t-4)^2]
THe program tells me this answer is correct.
I don't know how the do the last part of the equation at all. A is an unknown, but t is a variable as well...I tried using a hint in the program but it just tels me the answer should be vmax = A * sqrt [145]
I thought maybe, you find the derivative of v(x) and check when it's zero, then you know it's maximum velocity. But in the answer given, the derivative of v(x) is supposed to have v in the denominator, and I don't see how they got that answer...and then what? Where did the t go to get that final v max?
Welcome to PF!
Hi theowne! Welcome to PF! :smile:
Hint: you're only asked for 0≤t≤4 …
the maximum may be at dv/dt = 0, or it may be at 0 or 4 :wink:
EDIT: hmm … just noticed :redface: … you can see where the maximum is without any hard work …
v is a maximum when t(t - 4) is a maximum, isn't it? :smile:
  • · Replies 16 ·
