Orthologous vs Paralogous genes
  • Thread starter Thread starter BoundByAxioms
    Genes
The discussion centers around the concepts of orthologous and paralogous genes, exploring their definitions, relationships, and distinctions. Participants seek clarity on these terms, which are relevant in evolutionary biology and genetics.
  • Some participants define orthologous genes as those that have the same function in different species, while paralogous genes arise from a common ancestor within the same genome.
  • Others argue that orthology and paralogy are defined by the mode of separation of genes, emphasizing that both concepts assume a common ancestry.
  • A participant elaborates that orthologous genes diverge due to speciation events, while paralogous genes result from gene duplication.
  • Another participant mentions that orthologous genes are passed through generations and may be found in separate gene pools due to speciation, while paralogous genes can mutate and develop new traits while retaining the original function.
  • One participant challenges earlier definitions, stating that the function of genes does not determine their classification as orthologs or paralogs, and that tracing their relationships can be complex.
Participants express differing views on the definitions and implications of orthologous and paralogous genes. There is no consensus on the definitions, and the discussion remains unresolved regarding the nuances of these concepts.
Participants highlight the complexity of tracing gene relationships in phylogenetic trees and note that function may not correlate with orthology or paralogy in many cases.
BoundByAxioms
I am having trouble wrapping my mind around these concepts. Can anyone explain them clearly, and in relatively simple terms?
Biology news on Phys.org
Orthologuous means proteins that have the same function in different species and that may or may not have arisen from a common ancestor.
Paralogous means genes that have arisen from a common ancestor and are present in the same genome. Pararolgue may or may not have the same function.
Ortho same function different species, para common ancestor one species.
Great, thank you!
Actually paralogy or orthology do not refer to function and only to a limited amount on the occurrence within or between species, but rather to the mode they were separated.
Both concepts, homology and orthology assume a relatedness of the genes, meaning that they are always derived from common ancestors. In other words, you can trace both back to an ancestor in phylogenetic tree. The way the divergence of any two genes can be traced back defines whether they are paralogous or orthologous to each other.
Orthologous genes diverge by speciation events, whereas paralogous genes are the result of gene duplication.
Well lots of people had this question, so my professor reiterated these ideas in class.
Orthologous genes are genes that are passed from one generation to the next; these genes may be found in separate gene pools due to speciation.
Paralogous genes are genes that are duplicated, by chance, but remain in the same genome. Then, if one of the copies begin to change and mutate, a new, favorable trait may arise. The original function of the gene is still being carried out, however, due to the copy of the gene that did not change.
Hmm while partially correct, it is not used in the sense in which the term was coined (depends on what precisely was said though, maybe a bit was misinterpreted).
Again: orthology refers to a separation by speciation. This means that it refers to two genes in two different species that derive from a single gene of the last common ancestor
For instance a species 1 (S1) splits into two species: S2 and S3.
S1 carries a gene A. S2 got a copy of this gene (gene A2) and S3 got a copy (gene A3). Gene A2 and A3 are orthologs of each other.
Paralogy is more complicated, it refers to separation by duplication, but it can happen either before, or after speciation. In other words, it can be found in a single genome, but it does not has to be.
Let us take the above scenario, gene A2 gets duplicated. We then got gene A2, gene B2 (its duplicate) and finally gene A3 (from species S3). Here gene A2 and B2 would be paralogs, whereas both would be an ortholog of gene A3.
But we can do more complicated. Let us assume that in the last common ancestor of species 2 and 3 there is a duplication event resulting in the paralogous genes X and y Now assume three species each carrying one of those copies, e.g. species 1 carries gene X, S2 gene Y and so on. despite the speciation, gene X and Y would be considered paralogs, as their split was due to a duplication event.
As you can imagine in very complicated trees it is hard if not impossible to really trace down the relationship between any two genes. Moreover, while it has been sometimes added to the definition, the function has in reality nothing to do with the classification as orthologs or paralogs. While in some cases orthology correlates with function, in many more other cases (transcription factors are notorious for that) it does not.
In any case, the original definition only tracks back their relationship, not their functions.
