Entropy of an adiabatic process
This discussion focuses on calculating thermodynamic properties for a sample of 1.00 mol of an ideal gas undergoing adiabatic expansion. The gas is expanded both reversibly to 0.5 atm and against a constant external pressure of 0.5 atm. For the reversible process, the final temperature T_2 is calculated to be 227.357 K, with changes in internal energy (ΔU) and enthalpy (ΔH) determined as -905.931 J/mol and -1509.884 J/mol, respectively. The entropy change for the reversible process is debated, while the approach for the irreversible process is clarified through the first law of thermodynamics and the definition of entropy.
  • Understanding of ideal gas laws
  • Familiarity with thermodynamic equations, specifically for adiabatic processes
  • Knowledge of the first law of thermodynamics
  • Concept of entropy and its calculation in reversible and irreversible processes
  • Study the derivation of the entropy change for reversible adiabatic processes
  • Learn about the first law of thermodynamics and its applications in non-reversible processes
  • Explore the concept of heat capacity and its role in thermodynamic calculations
  • Investigate the differences between reversible and irreversible processes in thermodynamics
Students and professionals in thermodynamics, chemical engineering, and physical chemistry who are looking to deepen their understanding of adiabatic processes and entropy calculations.
luna02525
A sample of 1.00 mol of an ideal gas at 300 K and 101325 Pa is expanded adiabatically in two ways: a) reversibly to .5 atm and b) against a constant external pressure of .5 atm. Determine the values of q, w, [tex]\Delta[/tex]U, [tex]\Delta[/tex]H, [tex]\Delta[/tex]S, [tex]\Delta[/tex]Ssurr, and [tex]\Delta[/tex]Stot for each path where the data permit. Take C_v,m = 3/2 R (HINT: For part b: use the fact that [tex]\Delta[/tex]U = w = nC_v[tex]\Delta[/tex]T = -Pext[tex]\Delta[/tex]V to find the final temperature, and then construct a reversible path of 2 steps, where P and T change only one at a time.
q = 0 in all adiabatic processes
C_p,m = 5/2*R
C_v,m = 3/2*R
[tex]\Delta[/tex]U = w = int C_p dT
[tex]\Delta[/tex]H = int C_v dT
[tex]\Delta[/tex]S = [tex]\Delta[/tex]H/T = intC_p/T dT
for part a) reversible adiabatic: T_2/T_1 = (P_2/P_1)^[(gamma-1)/gamma] where gamma = C_p/C_v = 5/3
for part a)
I used the equation for an ideal gas in reversible adiabatic expansion to find T_2
T_2/300 K = (50662.5 Pa/ 101325 Pa)^(2/5)
T_2 = 227.357 K
from there I got [tex]\Delta[/tex]U = w = -905.931 J/mol and [tex]\Delta[/tex]H = -1509.884 J/mol
For part a I am unsure of how to find entropy of an adiabatic system expanding reversibly...my ideas:
[tex]\Delta[/tex]S = 0 [tex]\Delta[/tex]S_sys = C_p*ln(T_2/T_1) = 5.76 J/k mol, and therefore [tex]\Delta[/tex]S_tot = 5.76 J/k mol but this seems like an unreasonable answer.
And for part b I am sort of lost for where to start.
1) I know all of the above stated equations and unknowns. And that hint to find T_2 but I don't know how to find it! I have plugged in Starting P, n, and T's into the ideal gas equation but this only yields V_1 to plug into my work equation to find T_2.
Thank you for your time reading this and possibly responding :D
Start with the definition. For reversible processes: dS = dQ/T
[tex]\int_A^B dS = S_B - S_A = \Delta S = \int_A^B dQ/T[/tex]
If dQ = 0 for the gas, then what is dQ for the surroundings? What, then is dS and, therefore, [itex]\Delta S_{surr} \text{ and } \Delta S_{gas}[/itex]?
This is a little trickier. dS = dQ/T only for reversible processes.
For expansion at constant pressure, it is a simple matter to determine the work done: [itex]W = P\Delta V[/itex]. Use the first law, dQ = dU + dW to determine what [itex]\Delta U[/itex] will be when expansion is complete and this will give you the temperature of the gas. Since entropy is a state function, the change in entropy in the non-reversible process will be equal to the entropy change resulting from a reversible path between those two states.
AM
  • · Replies 19 ·
