Interpretation of the Tanabe Sugano diagram
The discussion revolves around the interpretation of the Tanabe Sugano diagram, specifically focusing on estimating the values of Δ and B for transition metal complexes, such as Ni2+ and Co3+. Participants explore the relationships between electronic transitions and their corresponding energy values, as well as methods for determining the ratios of these transitions.
  • Some participants discuss the estimation of Δ and B using the Tanabe Sugano diagram for Ni2+, noting specific transition energies (V1, V2, V3) and their ratios.
  • There is a question about how to determine the value of Δ/B from the ratio of transition energies, with some participants expressing difficulty in this estimation.
  • Several participants inquire about methods to find the corresponding point on the x-axis of the diagram that matches the ratio of transition energies, debating whether a trial-and-error approach or a more systematic method is preferable.
  • One participant suggests that solving two mathematical equations could yield a more accurate result for finding the x-axis point.
  • Another participant provides an example involving Co3+ and discusses the process of finding ratios and corresponding values on the Tanabe Sugano diagram, sharing their experience and methods used.
Participants express varying opinions on the best methods for determining values from the Tanabe Sugano diagram, with no consensus reached on a single approach. Some favor mathematical solutions, while others suggest graphical or software-assisted methods.
Participants highlight the need for specific diagrams (e.g., d3, d6) and mention the importance of selecting appropriate transition lines, indicating that the discussion may depend on the definitions and assumptions related to these diagrams.
Kenji Liew
We can estimate the value of Δ and B from Tanabe Sugano diagram. For example Ni2+ which is has the electronic configuration of d8. So, by referring the d8 Tanabe Sugano diagram, we can can noticed that there are 3 types of transition. The transitions are observed as V1=8500cm-1, V2=13800cm-1 and v3=25300cm-1. We can take the ratio V2/V1=1.624. But the problem is, from the ratio ,how can we determine value of the vertical axis, that is Δ /B? :frown:Due to this problem, I find the difficulty to estimate the value of Δ and B.
In addition, how can we explain the further splitting of the spectrum? Thanks.:rolleyes:
You need to find the proper diagram - d3 , d6 , etc...
Then deduce all of the transitions
Then find the point on the x-axis where the ratio of values between the transitions equals your ratio for the wavelenghts.
Visit my link to find some applets on Tanabe-Sugano diagrams.
Hi, thanks for your explanation. But you still don't explain how to find the point on the x-axis where the ratio of values between the transitions equals with the ratio for the wavelengths.Try and error? or got suitable method? From the URL you provide, I notice that the point on the x-axis is given after ratio is known.It don't explain how we get the x-axis point Thanks!
Once you find the proper diagram as well as the right two lines you are able to skim across to find the point that corresponds to your ratio , this may be done manually which would be an approximation or use a software such as that provided on the directed website.
One other thing , if you are able to know of the equation of the two lines then there is a mathematical way of getting an exact answer ... if you are in need of it reply to this message.
I think to make life easy,solving two mathematical equations and then get the point of x-axis is the better way. The answer may more accurate. If I use the method of skim across, this may take some time to do this. So, can you show me an example or a guidance to do this by solving two mathematical equations? Really thanks for your help.
If you used that software that was included in that link that I mentioned then it would only take seconds ... I don't have the time to give you an example , it's actually been a while since I came across this topic.
equation 1 - y1 = x1c1 + b1
equation 2 - y2 = x2c2 + b2
v2 / v1 = C
C = ( x2c2 + b2 ) / ( x1c1 + b1 )
x2 = x1
C = ( xc2 + b2 ) / ( xc1 + b1 )
Solve for x
In case anybody is looking for the issue of X axis again here it is:
Example:
The complex [Co(H2O)6]+ has two d-d absorption bands at 16,600 cm-1 and 24,800 cm-1
Looking at the Tanabe-Sugano diagram specifically for d6 (Co3+ is d6) we can see that the transitions are 1T1g <-- 1A1g and 1T2g <-- 1A1g transitions (right hand side because there are 2 transitions and it is low spin).
Then we find the ratio of the peaks 24,800/16,600 = 1.49, the next step is to find the D/B on the X axis:
You may have to try several values in order to find the ratio that is closest to 1.49.
In this situation you look at the height (Y axis) of 1T1g and 1T2g (this is where the 2 of your transitions will end up, look above) and find the ratio of these heights. To make things easier, look for the 'good-looking' values of D/B, like 40, 30, 25 etc, not random 11 or 26. In this example the right ratio is of 41/27 = 1.51, where D/B=30.
Then you do the rest of the calculations if you need to find D. (by substitution of E/B=27 - the value on the Y-axis where X-axis = 30; then E=16600 cm-1 and blaaaa)
Took me some time to figure things out, so I decided to share with people who are struggling. :)
  • · Replies 0 ·
