Pulleys - find force to accelerate a block
The problem involves two blocks, one stacked on top of the other, with a focus on determining the force required to accelerate the bottom block at a specified rate. The context includes considerations of friction between the blocks and the surface, as well as the effects of gravity.
  • Participants discuss the forces acting on each block, including friction and normal forces. There is confusion regarding the role of tension in the system and how it relates to the acceleration of the blocks. Some participants express uncertainty about the coefficients of friction used in their calculations.
Several participants have attempted to set up equations based on Newton's laws but have encountered discrepancies in their results. There is ongoing exploration of the relationships between the forces acting on the blocks and the overall system dynamics. Some guidance has been provided regarding the need to consider tension and the correct application of forces.
Participants note that the problem involves a pulley system, which introduces additional complexity regarding the acceleration of the blocks. There is mention of a deadline for submission, adding urgency to the discussion.
Pakbabydoll
A force F acts to the right on a 5.65 kg block. a 2.29 kg block is stacked on top of the 5.65kg block and can slide on it with a coefficient of friction of .15 between the blocks. The table has a coefficient of friction of .18. G= 9.8 m/s^2
system is in equilibrium
Find the F required to accelerate the 5.65kg block at 2m/s^2. answer in units of N
I am lost... I tried but it was wrong and now I have no idea what to do...
Show what you've tried.
What forces act on each block?
So this is what I have its probably completely wrong because I did it this way and a graduate physics student did it another way but both of our answers are wrong.
N-(M1+M2)g
(2.29+ 5.65)9.8
77.812(.18)= 14.006
(2.29)(9.8)(.18)= 4.03956
F-(f1+f2)=ma
F-(14.006+4.03956)=7.94(2)
F=33.92576 (wrong answer)
I did not even understand what the graduate student but her answer was 30.9800 (also wrong)... so do u guys have any idea? sorry it took me so long to get back but I had an orgo exam and I have been crazy studying for it.Please help me... thanks
N-(M1+M2)g
(2.29+ 5.65)9.8
77.812(.18)= 14.006
This is the friction from floor. Good.
Wrong coefficient of friction.
F-(f1+f2)=ma
Two problems: Wrong friction from upper block & wrong mass used. (You are applying Newton's law to the bottom block.)
wrong again... sorry... ok so I was wondering since its a pully should not we multiply the bottom acceleration by 2. umm so the bottom block would be moving twice as fast as the top block? am I making any sense? o and I have one try left to plug in the answer so can someone do this for me please? If I am wrong one more time I get negative score..:(
Other than the title of this thread, this is the first time you mentioned a pulley. (I assumed that the title was a mistake, since you didn't mention a pulley in the problem statement.)
Why don't you describe the problem completely, exactly as given? Got a diagram?
yes sir I am going to attach the hwk file. it is problem #15
so any help guys?
Now the problem is clear. OK, so what's your attempted solution for this problem?
Redo your earlier solution, this time taking into account the string tension forces on each block and the constraint that the blocks are attached. Analyze the forces on each block and apply Newton's 2nd law.
That was my solution for that problem! I am stuck at that point
But you made no mention of tension forces or constraints. (That's why I thought your title was an error--you didn't mention a pulley in the problem statement.)
Anyway... What forces act on each block?
ok so there is:
Friction between top and bottom block
Friction between bottom block and the tile
Normal force but would not that just cancel with gravity?
Tension in + and - X^ directions (since all the motion is in the X^ )
Oh and I can't turn that problem in anymore it was due this morning but I really just want to get it because that was the only one from that hwk set I could not figure out. I don't know if you noticed but those problems were really hard.
Pakbabydoll said:
ok so there is:
Good. Don't forget the applied force F.
Look at each block in turn. Indentify the (horizontal) forces acting and set up Newton's 2nd law. You'll get two equations (one for each block). If you combine them you can solve for F.
How are the tensions acting on the blocks related? The accelerations of the blocks?
Hard problems are good for you! :-p
g=9.8 ms^-2
a=2 ms^-2
u1= coefficient of friction between the two blocks
The upper pulley acc. at 1/2 of the acc. of the bottom block.
So I got 2T-2.29*g*u1=2.29*a/2
T=2.83 N
F-5.65*g*u2-T=(5.65+2.29)*a
F=20.73 N
Please do not post complete solutions to problems.
OK.
This equation is incorrect.
fırstly
2T-2.29*9.8*0.15=(a=1*2.29) T=2.82815
F-(2.29*0.15*9.8)-T-((5.65+2.29)*9.8*0.18)=(a=2*5.65)
F=30.61450600
İS MY ANSWER RIGHT?
