Calculating Altitude and Time of a Fired Rocket
  • Thread starter Thread starter rocomath
    Models Motion
The problem involves a rocket fired vertically with constant acceleration, transitioning to free fall after the motor shuts off. Participants are discussing how to calculate the maximum altitude and the total time until the rocket returns to Earth, while ignoring air resistance.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are exploring methods to calculate the maximum height and total time of flight, discussing integration of acceleration to find velocity and position functions. There is a suggestion to treat the motion in two phases due to changing acceleration.
Some participants have confirmed the initial approach to finding the maximum height, while others are considering modifications to the position function to account for varying acceleration. There is an ongoing exploration of integrating to find velocity and position.
Participants are working under the assumption that air resistance can be ignored and are navigating the complexities of changing acceleration during the rocket's flight.
rocomath
A rocket is fired vertically and ascends with constant acceleration a=100m/s^2 for 1min. At that point, the rocket motor shuts off and the rocket continues upward under the influence of gravity.
a) Find the maximum altitude acquired by the rocket
b) The total time elapsed from the take-off until the rocket returns to the earth
Ignore air resistance.
a) The maximum height can be found through setting velocity equal to zero, and the integral of acceleration is velocity.
[tex]\int_0^Ta(t)dt=\int_0^{60}a(t)dt+\int_{60}^Ta(t)dt=0[/tex]
[tex]\int_0^Ta(t)dt=\int_0^{60}100dt-\int_{60}^T9.8dt=0[/tex]
T=672.244898s
Is (a) good so far?
(a) looks good so far.:smile:
yay! Thanks for the confirmation.
Ok, so I have the time when my rocket is at it's highest. I know the position function equation, but I can't use it since my acceleration isn't constant.
Can I modify it such that [tex]x_1(t)[/tex] has g=100, and [tex]x_2(t)[/tex] has g=9.8, and the maximum height is just [tex]x_1+x_2[/tex]?
Well [itex]a(t)=\dot{v}(t)[/itex] so why not integrate a(t') from t'=0 to t'=t to find the speed of the particle at a time t the same way you did to find v(T). Treat two cases, t<60min and t>60. this should give you the piecewise function for v(t). Then, repeat the process to find x(t) and finally plug into the equation to find x(T).
Oh ok, so just keep on integrating! Let me try it.
  • · Replies 18 ·
