Calculating Average Velocity from Position vs Time Graph
  • Thread starter Thread starter chanv1
    Position Time
The discussion revolves around calculating average velocity from a position versus time graph for a particle moving along the x-axis. Participants are tasked with finding average velocities over specified time intervals based on the provided graph.
  • Participants discuss the formula for average velocity, questioning the application of the equation x(t_2) - x(t_1) / t_2 - t_1. There is confusion regarding the interpretation of x(t_2) and the values to be used in the calculation.
Some participants are attempting to clarify the formula and the values they should use, while others express uncertainty about their calculations. There is an ongoing exploration of the correct interpretation of the average velocity formula, and some guidance has been offered regarding the proper substitution of values.
Participants are working with a graph that is not visible in the thread, which may lead to misunderstandings about the position values at specific times. There is also a mention of potential rounding issues affecting the answers provided.
chanv1
The position versus time for a certain particle moving along the x-axis is shown in the figure below.
http://img87.imageshack.us/img87/6101/physicswg4.th.jpg http://g.imageshack.us/thpix.php
Find the average velocity in the following time intervals.
(a) 0 to 4 s
_____ m/s
(b) 0 to 5 s
_____ m/s
(c) 4 s to 5 s
_____ m/s
(d) 5 s to 7 s
______ m/s
(e) 0 to 8 s
______ m/s
I thought the equation to use would be x(t_2) - x(t_1) / t_2 - t_1
After following that equation, I got 5 m/s for (a), but it was incorrect.
Could someone PLEASE tell me what I did wrong. Thanks.
Hi chanv1,
(a) 0 to 4 s
_____ m/s
(b) 0 to 5 s
_____ m/s
(c) 4 s to 5 s
_____ m/s
(d) 5 s to 7 s
______ m/s
(e) 0 to 8 s
______ m/s
Your equation looks right to me; but I am not getting 5m/s for part a. What numbers are you plugging into your equation (for x(t2), x(t1), t2, and t1) to get 5m/s?
I did
5(4) - 0(0) / 4-0 = 5
What answer did you come up with? and would you please show me how?
chanv1 said:
I did
I think you are visualizing the formula incorrectly. It is:
[tex] v_{\rm ave} = \frac{x(t_2)-x(t_1)}{t_2-t_1}[/tex]
and [itex]x(t_2)[/itex] is not x times [itex]t_2[/itex]. So it might be better to write it as:
[tex] v_{\rm ave} = \frac{x_2-x_1}{t_2-t_1}[/tex]
because [itex]x(t_2)[/itex] means the position x at time [itex]t_2[/itex], so [itex]x(t_2)=x(4 \mbox{ seconds}) = 5\mbox{ meters}[/itex]
Yeah, I know. I don't understand what I'm doing wrong ... please walk me through this?
Isn't the distance for 4s, 5? so I would 5 * 4 = 20 and so on?
What should I be seeing instead?
I seem to be having some computer problems, so I'll repost the edits I made in my last post in case they just are not showing up.
it might be better to write the average velocity formula as:
because [itex]x(t_2)[/itex] means the position x at time [itex]t_2[/itex], so [itex]x(t_2)=x(4 \mbox{ seconds}) = 5\mbox{ meters}[/itex], not 20.
so would the answer then be 1.25 or 1.3?
but that answer was incorrect too.
Unless I'm just not seeing something, it looks like 1.25m/s is the correct answer to me. (Since you mentioned 1.3m/s, did you try 1.25 or did you input the rounded answer?)
yeah, I rounded the number. Silly me!
Thanks for all your help!
Sure, glad to help!
  • · Replies 40 ·
  • · Replies 30 ·
