QM Collisions: How Two Particles Interact
  • Context: Graduate
  • Thread starter Thread starter wofsy
    Collisions Qm
The discussion centers around the concept of particle collisions in quantum mechanics (QM), particularly how two particles can interact according to the Schrödinger equation. Participants explore the differences between classical and quantum descriptions of collisions, the implications of wave function superposition, and the nature of scattering processes.
  • One participant questions how collisions can occur in QM if particles evolve according to the linear Schrödinger equation, which suggests superposition rather than classical collision.
  • Others argue that collisions can occur in QM through scattering processes, which are covered in many QM texts.
  • Some participants emphasize the need to abandon classical intuitions about collisions, suggesting that quantum particles do not have well-defined trajectories.
  • A participant proposes that the interaction between particles can be described by a potential that allows for solutions resembling collisions, despite being fundamentally different from classical collisions.
  • Another participant suggests using wave packets to better understand the nature of collisions in QM.
  • There is a discussion about the limitations of applying QM to macroscopic objects, with some arguing that while it is theoretically possible, it is not practical due to the scale differences involved.
  • Participants express confusion about the nature of two-particle wave functions and the role of potentials in defining interactions between particles.
Participants do not reach a consensus on the nature of collisions in QM. There are competing views on how to interpret the interaction of particles, the applicability of classical concepts, and the role of potentials in quantum scattering.
Some participants note the importance of understanding scattering theory and the limitations of classical analogies in quantum mechanics. There are unresolved questions regarding the measurement problem and the formulation of multi-particle wave functions.
wofsy
As a beginner in QM I have a question that I could not find answered in my books.
Two particles evolve happily according to the Shroedinger equation. How can they collide? In classical mechanics they collide when their trajectories intersect and their motion is then calulated using the conservation of momentum and energy.
But in QM the wave functions just superpose. There is no collision.
Where have I gone wrong?
You have assumed they can't collide and more or less stopped there. Of course they can. Most QM books even cover scattering.
You also assume that particles like protons for instance must collide and react like tiny balls. But the interaction (force) between particles has a certain range, and you also have the wave function, so there is a certain probability for the two particles involved to be confined within a region where the force can act between them.
And as Vanadium_50 said, QM scattering is what you are looking for.
Thanks for the reply but I am still confused.
I did not assume that collisions can't occur. I just said that I could not see how they could occur from the Schroedinger equation since it is linear and its solutions will always superpose. Superposition does not allow collision.
In scattering I guess you are saying that there is a potential that leads to solutions that appear macroscopically like collisions but aren't really. They are just solutions of the Shroedinger equation.
Is this right?
What do you mean with the concept of "collisions"? Two small balls hitting each other? You must abandon such classical pictures when doing quantum mechanics.
Ok then let's take this case. A batter hits a baseball for a home run. The trajectory of the ball is changed after contact with the bat. How do you explain that using the Shroedinger equation?
Quantum particles don't have trajectories... you are applying classical thinking into quantum mechanics. Grab a intro book on quantum mechanical scattering.
Here is quite good internet source:
https://www.physicsforums.com/showthread.php?t=220904
https://www.physicsforums.com/showthread.php?t=220901
Ok thanks
In the case of the baseball, QM must be able to explain ths homerun in terms of a change in the group velocity of the wave function. My question was how this arises from the Schroedinger equation.
I will read the lins you sent. Thanks again.
Try to apply QM to macroscopic stuff if you want, it will not work ;-)
Those links are very good and are suitable as introductory books in QM.
if the shroedinger equation is right then it must apply to the baseball.
I read how classical equations are approximated through the group velocity of the wave function
It is quite meningless to talk of a wave function of macroscopic object such as an baseball, but in principle you could do it. I'll suggest you learn QM scattering of electrons, protons etc so you learn how to do it. Then you can apply it to a particle of mass 100g ;-)
The DeBroigle wavelength of a baseball is many times smaller the R.M.S radius of a proton...
Notice the word "approximation"...
Is this right?
No, this is not right. To see this, take two particles with equal masses and no spin, moving in opposite directions, interacting by means of a 1- D "central" force(depends on the difference in coordinates, |x1 - x2|), say a potential well of finite extent. Then, of course, you can translate this problem into one of a single particle dealing with a potential well. Further, the solutions of this problem are well known, and can be found in almost any QM book ever written. Then translate back to the original problem, and see very clearly that 1. a "collision" does happen, and 2. the solutions are not linear in the coordinates of the particles, and 3. superposition is an essential feature of scattering and interactions.
If you want to be a bit more rigorous, use wave packets, which will help in elucidating the collision that occurs.
For a more general discussion, look up scattering theory which will help you to understand collisions as they are described in QM .
Regards,
Reilly Atkinson
You can have a wavefunction over two particles [tex]\Psi(x,y)[/tex] and write down a potential V(x,y), which describes the interactions of this two particle state.
Note also that you can add two solutions of a Schrödinger equation which gives you also a solution again to the Schrödinger equation you dealing with.
But when you have two wave functions being solutions of two different Schrödinger equations ( one for particle x, one for particle y), then you can not add/ superpose these two in order to give you a solution to any interacting.
right. that makes total sense. thanks. could you give me an example of a two particle wave function? Is it the product of the wave functions of the separate particles?
Why can't the measurement problem be solved with multi-particle solutions to the Shrodinger equation?
oh yeah it can not be the product because the potential must involve both of them
Regards,
Reilly Atkinson
why well? don't you mean potential barrier? anyway what are you using for the potential :wink:
  • · Replies 70 ·
  • · Replies 22 ·
