Creating lift equation-NEED HELP
  • Thread starter Thread starter FutureFighter
    Lift
The discussion focuses on deriving a lift equation based on three parameters: Area (A), air density (ρ), and velocity (v). The proposed relationship for lift (L) can be expressed as L(A, ρ, v) = C * A * ρ * v², where C is a constant of proportionality. Participants emphasize the direct correlation between Area and lift, the impact of air density on lift generation, and the significance of velocity in the lift equation. Understanding these relationships is crucial for accurately modeling lift in aerodynamics.
  • Basic understanding of aerodynamics principles
  • Familiarity with the concept of lift in fluid dynamics
  • Knowledge of the variables affecting lift: Area, air density, and velocity
  • Mathematical skills for manipulating equations
  • Research the derivation of the lift equation in aerodynamics
  • Explore the role of the constant of proportionality in physical equations
  • Learn about the effects of varying air density on lift generation
  • Study the relationship between velocity and lift in different flight conditions
Aerospace engineering students, physics enthusiasts, and professionals involved in aerodynamics and flight mechanics will benefit from this discussion.
FutureFighter
Creating lift equation---NEED HELP!
For a course I am taking, I need to determine a lift equation based on some variables.
Propose an equation for lift as a function of your three parameters. That is, if L=lift, A=Area, ρ=air density, and v=velocity, determine L(A, ρ, v).
I am just so lost--any help would be most appreciated!
Welcome to PF.
What do you think? How will Area affect Lift? Will it get larger with larger area or smaller?
Same with Air Density. Do you expect that you can get greater lift with denser air or thinner air?
Same again with velocity. Bigger lift with greater V or smaller?
Take the expression F = M*A The Force is greater for greater Mass or greater acceleration. But for the same Force greater Mass means smaller acceleration.
They want you to develop a relationship that reflects these interrelationships of the variables presented.
(As a tip: It can't hurt to put a constant of proportionality in, even if it turns out to be 1.)
10K
