Constant Volume and Constant Pressure Batch Reactor
The discussion revolves around the analysis of two types of isothermal batch reactors for the decomposition of A to B, focusing on the differences in behavior under constant volume and constant pressure conditions. Participants are addressing a homework problem that involves calculating the fractional decrease in concentration and total molar conversion after a specified time.
  • Homework-related
  • One participant notes that for the constant volume reactor, the solution is straightforward, yielding the relationship \(\frac{C_{A}}{C_{A0}}=exp(-kt)\).
  • Another participant suggests using a Laplacian transform of the Ideal Gas equation to derive a Gaussian form for concentration in the variable volume reactor, proposing that the concentration relationship will involve an error function.
  • A different participant expresses confusion regarding the steps involved in the suggested approach and requests clarification.
  • Another participant humorously acknowledges their previous misunderstanding and suggests using the Ideal Gas equation to calculate changes in volume, hinting at the importance of assumptions made in the context of the Ideal Gas law.
Participants do not appear to reach a consensus on the approach to solving the variable volume reactor problem, with differing suggestions and levels of understanding evident in the discussion.
The discussion highlights potential limitations in understanding the application of the Ideal Gas law and the assumptions necessary for the mathematical modeling of the reactors. There is also uncertainty regarding the steps needed to solve the problem for the variable volume reactor.
Students and practitioners interested in chemical engineering, particularly those studying reactor design and kinetics, may find this discussion relevant.
missmaria
Consider the following two well-mixed, isothermal batch reactors for the elementary and irreversible decomposition of A to B, A[tex]\stackrel{k}{\rightarrow}[/tex]2B
reactor1: The reactor volume is constant (Pressure is variable)
reactor2: The reactor pressure is constant (Volume is variable)
Both reactors are charged with pure A at 1.0 atm and k=0.35min[tex]^{-1}[/tex]
a) what is the fractional decrease in the concentration of A in reactors 1 and 2 after 5 minutes?
b)what is the total molar conversion of A in reactors 1 and 2 after 5 minutes?
Since reaction is first order: r[tex]_{A}[/tex]=-kC[tex]_{A}[/tex]
Ok, so part a for a constant volume reactor was simple, since the ODE was easy and it turned out that [tex]\frac{C_{A}}{C_{A0}}[/tex]=exp(-kt)
but variable volume has me stumped. I figured out that -k=[tex]\frac{dC_{A}}{dt}[/tex]+([tex]\frac{1}{V}[/tex])([tex]\frac{dV}{dt}[/tex] but i don't know where to go from here.
I don't even know where to start for part b, please help...
This problem is a bit complicated, but I remember it from my days as an undergraduate. You have to use a Laplacian transform of the Ideal Gas equation (assuming that T is high enough at 1atm to support this assumption). This should give you an equation for concentration in the form of a Gaussian, which, when integrated, will give an error function. You should work this out for yourself, but your answer should be of the form:
Ca / Cao = erf(-Vr * k * t)
Hope this helps.
I'm not sure i understand what exactly you mean, could you spell it out stepwise?
just kidding. You actually use the Ideal gas equation and (think about the assumptions made for the ideal gas law) calculate delta(V). Then, think about what Cj means
9K
