Thread Closed
Need help calculating the pressure in the bottle
Share Thread Thread Tools
Sep30-08, 06:58 PM   #1
Liquid helium at 4.2 K has a density of 0.147 g/mL. Suppose that a 2.50-L metal bottle that contains air at 105K and 2.0 atm pressure is sealed off. If we inject 100.0 mL of liquid helium and allow the entire system to warm to room temperature (25 °C), what is the pressure inside the bottle?
This is what I have so far
For air alone-
P/T = P1/T1
2.0 / 105 = P1 / 298
P1 = 5.676 atm
For He alone-
100.0 mL x 0.147 g/mL = 1.47 g
1.47 g/ 4.00 g/mol = .3675 mol
P=nRT/V=.3675x0.08206x298/2.50=3.595 atm
Ptotal = 3.595 + 5.7 = 9.296 atm
But apparently the answers wrong. Can someone please help?
Addtional Hints:
At the end of the problem, the bottle contains both helium and air, and we want the total pressure. You know V (same as the initial V of the metal bottle) and T, so if you knew n you could solve for P. Find the number of moles of air and of helium separately, then add them to get the total number of moles of gas in the bottle. I will add that you need to use two pretty different ways to find the moles of the two gases.
does anyone know how to solve for the mole (n) in pv=nrt for this equation....maybe if I find the number of moles individually for both then I can solve...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Sep30-08, 08:30 PM   #2
Mentor
> "100.0 mL x 0.147 g/mL = 1.47 g"
Try that one again.
Sep30-08, 08:51 PM   #3
okay i realized that and fixed it but i still get the wrong answer...i used 14.7 g this time
Sep30-08, 09:03 PM   #4
Mentor
Huh, I'm not sure what else is wrong. But I didn't check the rest of it, did you use consistent units for the ideal gas equation?
Sep30-08, 09:06 PM   #5
yes I used k for temperature and the right constant value
Sep30-08, 09:55 PM   #6
GCT
Recognitions:
Homework Helper Homework Help
Quote by mhn745 View Post
For air alone-
P/T = P1/T1
P1 = 5.676 atm
For He alone-
Addtional Hints:
Check your MW for Helium gas.
Oct1-08, 02:48 AM   #7
Admin
What was your final result?
How many significant digits have you entered?
4.00 is a correct MW for helium.
Oct1-08, 11:41 AM   #8
GCT
Recognitions:
For air alone-
P/T = P1/T1
P1 = 5.676 atm
For He alone-
Addtional Hints:
Is the answer 42 atm?
Thread Closed
Thread Tools
Similar Threads for: Need help calculating the pressure in the bottle
Thread Forum Replies
calculating pressure gradient Engineering, Comp Sci, & Technology Homework 0
pressure in a glass bottle Introductory Physics Homework 1
Calculating pressure Chemistry 17
calculating pressure Introductory Physics Homework 0
Impulse thrust calculations from pressure bottle Classical Physics 6
