How can I determine the vertical distance the ball clears the wall?
  • Thread starter Thread starter -EquinoX-
    Dimensions
The discussion focuses on calculating the vertical distance a ball clears a wall after being launched at an angle of 53 degrees from a point 24 meters away from the wall. The ball is launched from a height of 6.00 meters, with the wall being 7.00 meters high. The initial velocity of the ball was determined to be 18.1 m/s using the equation 24 = Vi*cos(53)*(2.2). To find the height the ball clears the wall, participants suggest using kinematic equations that incorporate initial velocity, acceleration, and the final velocity at the maximum height, which is zero.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Basic trigonometry for resolving components of velocity
  • Knowledge of gravitational acceleration (9.81 m/s²)
  • Study kinematic equations for vertical motion in projectile problems
  • Learn how to resolve velocities into horizontal and vertical components
  • Explore the concept of maximum height in projectile motion
  • Practice similar problems involving angles and distances in projectile motion
This discussion is beneficial for physics students, educators, and anyone interested in understanding projectile motion and its applications in real-world scenarios.
-EquinoX-
A playground is on the flat roof of a city school, 6.00m above the street below. The vertical wall of the building is 7.00 m high forming a 1m high railing around the playground. A ball has fallen to the street below and a passerby returns it by launching it at an angle of 53 degrees above the horizontal at a point 24 m from the base of the bulding wall. The ball takes 2.20 to reach a point vertically above the wall. Find the vertical distance by which the ball clears the wall.
I can get the initial velocity first by plugging in the formula:
24 = Vi*cos(53)*(2.2) then
finding for Vi I get 18.1. Now how do I find the height the ball clears the wall?
You need an equation that has the distance the acceleration and the initial and final velocities in the y direction. You know at the max height the velocity in the y direction will be zero. You know the initial velocity and the acceleration and thus you can work out the height.
  • · Replies 24 ·
31K
