Calculating Torque on a Circular Loop in an External Magnetic Field
The discussion focuses on calculating the torque exerted on a circular loop carrying a current of 6.1 A in an external magnetic field of 5.5 T, with the angle between the field and the plane of the loop being 42°. The torque is calculated using the formula torque = N * I * A * B * sin(theta), where A is the area of the loop. The area is derived from the radius calculated from the circumference of 110 cm, resulting in a torque of approximately 2.1616 N·m. A clarification regarding the angle theta indicates it should be subtracted from 90° for accurate calculations.
  • Understanding of torque calculations in physics
  • Familiarity with magnetic fields and their effects on current-carrying loops
  • Knowledge of trigonometric functions, specifically sine
  • Ability to calculate the area of a circle using the formula A = πr²
  • Study the derivation and applications of the torque formula in electromagnetic contexts
  • Learn about the effects of varying angles on torque in magnetic fields
  • Explore the relationship between current, magnetic field strength, and torque in different configurations
  • Investigate the implications of torque in practical applications such as electric motors
Students studying electromagnetism, physics educators, and engineers involved in designing electromagnetic devices will benefit from this discussion.
Kris1120
A current of 6.1 A is maintained in a single circular loop having a circumference of
110 cm. An external magnetic field of 5.5 T is
directed such that the angle between the field
and the plane of the loop is 42◦.
Determine the magnitude of the torque exerted on the loop by the magnetic forces acting upon it.
Answer in units of N · m.
torque = N*I*A*B*sin(theta)
A=pi*r^2
C=2*pi*r
r=1.1/(2*pi)
= 0.17507 m
A=pi*r^2
=pi*(0.17507 m)^2
=0.096288 m^2
torque = 1 loop * 6.1 A * 0.096288 m^2 * 5.5 T * sin(42)
= 2.1616 N*m
Hi Kris1120,
I believe you make an error later in applying this equation. What does the theta in this equation represent?
Oh I have to subtract theta from 90! Thanks!
  • · Replies 37 ·
