Find force link 3 exerts on link 2
  • Thread starter Thread starter jturn
    Force Link
The problem involves calculating the force that link 3 exerts on link 2 in a chain of five links, each with a mass of 0.105 kg, being lifted with a constant acceleration of 3.5 m/s². The correct approach utilizes the equation F = ma, where the total weight acting on link 2 must account for the gravitational force and the force due to acceleration. The accurate force exerted by link 3 on link 2 is determined to be 6.98 N, which includes the weight of the three links above link 2 and the additional force required for acceleration.
  • Understanding of Newton's Second Law (F = ma)
  • Basic knowledge of gravitational force calculations (weight = mg)
  • Familiarity with concepts of force and acceleration in physics
  • Ability to perform algebraic manipulations to solve for unknowns
  • Review the principles of Newton's laws of motion
  • Study the concept of tension in a system of connected objects
  • Learn about the effects of acceleration on forces in multi-body systems
  • Practice similar problems involving forces in chains or connected masses
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force calculations in multi-link systems.
jturn
A chain consisting of five links, each of mass 0.105 kg, is lifted vertically with a constant acceleration of a = 3.5 m/s2. Find the magnitude of the force that link 3 exerts on link 2.
F = ma
I did:
F = ma
FU - (0.105 * 3)(9.8) = (0.105) * 3.5
FU = 4.19 N
where FU is the force pulling up, (0.105*3) is the mass of the link's 5, 4, and 3 weighing down on link 2 (mg=weight) and then the mass*accel on the other side.
This is wrong. why? and how do i get the right answer?
does no one know how to do it? ...if it helps. i found the force required to move the top link at that acceleration to be 6.98 N...at it was the right answer...
F = ma
I did:
F = ma
FU - (0.105 * 3)(9.8) = (0.105) *3[/color] *3.5
FU = 4.19 N OK[/color]
It looks like your calculation and answer is correct, although you left out a 3 in an apparent typo omission (see above in red). Unless, the links are numbered 1 thru 5 bottom to top, rather than 1 thru 5 top to bottom??
  • · Replies 95 ·
  • · Replies 21 ·
11K
