Thread Closed
I keep getting errors in a simple copper sulfate experiment
Share Thread Thread Tools
Oct2-08, 08:54 AM   #1
I need to find the total number of water molecules per copper sulfate molecule. The answer is 5. But, I keep getting ~4 with the average of two dehydrating experiments.
2. Relevant equations with my Attempts
I am just using simple factor equations for these. I am converting from the weight of water that I liberated to moles. Then, comparing moles to find experimental values for the number of water molecules in the copper sulfate. I hope you understand. This is the first time I've tried to use LateX
Test 1
0.340g H2O * [tex]\frac{1 mol H_{2}O}{18.016g H_{2}O}[/tex] = 0.0189 mol H2O
0.6449g CuSO4 * [tex]\frac{1 mol CuSO_{4}}{159.62g CuSO_{4}}[/tex] = 0.00404 mol CuSO4
Experimental number of H2O Molecules is 4.68 or [tex]\frac{0.0189 mol H_{2}O}{0.00404}[/tex]
That's fine for that one, I can round up to 5 for the ratio.
For the second test, I used the same equations with the measured weight of 0.328g H2O and 0.729g CuSO4.
This gives 0.0182 mol H2O and 0.00457 mol CuSO4.
The experimental value for the number of H2O molecules comes out to 3.98.
This is where I am not doing so well (obviously). When I average these two and round off, I get 4. To the best of my knowledge, copper sulfate tetrahydrate doesn't exist.
So, am I just dealing with imperfect lab situations (technique, materials, etc..), or is there a fundamental flaw in my approach. Thanks for your time.
Mike
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct4-08, 04:35 PM   #2
GCT
Recognitions:
Homework Helper Homework Help
It's the former.
Thread Closed
Thread Tools
Similar Threads for: I keep getting errors in a simple copper sulfate experiment
Thread Forum Replies
Reaction involving copper (II) sulfate pentahydrate Biology, Chemistry & Other Homework 3
solubility for hydrated calcium sulfate in HCl Biology, Chemistry & Other Homework 1
Modification of Copper & Copper Alloys Materials & Chemical Engineering 4
Sources of errors on Determinating Faraday's Constant experiment Biology, Chemistry & Other Homework 1
Simple, simple question concerning errors needing quick answer Calculus & Beyond Homework 0
