Mysterious Wasp Infestation: My Home is Under Siege
    Home
The discussion revolves around a wasp infestation in a home, focusing on the unexpected presence of numerous wasps at a specific window. Participants explore potential entry points, control measures, and the implications for household pets. The conversation includes personal experiences and suggestions for dealing with the situation.
  • One participant describes a sudden influx of wasps at a window, expressing confusion about their entry point.
  • Several participants suggest using wasp traps, both inside and outside the window, as a potential solution.
  • There is speculation about possible entry points, including cracks in the window frame or other areas of the house.
  • One participant mentions that wasps typically head towards windows when inside a house, possibly indicating they are entering from another location.
  • Another participant shares an anecdote about finding insects during home renovations, suggesting that wasps can enter through cracks in siding or walls.
  • Concerns are raised about the safety of pets in the presence of wasps, with some participants emphasizing the need for caution.
  • Participants discuss the possibility of a wasp nest being hidden within the window frame or walls, which could explain the large number of wasps.
  • There are humorous exchanges about the participant's pet, referred to as a "Fruit Bat," leading to light-hearted speculation about the participant's identity.
  • One participant advises contacting pest control for assistance, while others suggest DIY methods for identifying drafts and sealing entry points.
Participants express a range of views on the source of the wasps and the best methods for dealing with them. There is no clear consensus on the exact entry point or the most effective solution, indicating ongoing uncertainty and debate.
Some suggestions rely on assumptions about the construction of the house and the behavior of wasps, which may not be universally applicable. The discussion also reflects varying levels of concern for personal safety and the well-being of pets.
Evo
Staff Emeritus
Over the past couple of days a large number of wasps have been getting inside my house. When I got home from work Monday and went to open the window next to my computer, there were 3 wasps between the blinds and window. I got the wasp spray and shot them down, before I could get something to dispose of them, 4 more wasps fell out of the window. I could not find where they had come from.
A couple of hours later, I heard the Fruit Bat scuffling with something and it was another wasp.
Yesterday when I came home, a war had obviously raged that day between a dozen wasps, my cat and my dog. Everything loose on my desk near the window was on the floor along with a dozen dead or squirming wasps. Last night the Fruit Bat took down another couple of wasps. I have checked EVERYWHERE for where they are getting in (they are only at this one window) and there are no holes, not even cracks. I've looked on the outside of the window and everything seems sealed up. I'm flaberghasted. It's like they are teleporting in. :bugeye:
I'm just hoping that a bunch don't get in today and harm Dr Foofer or the Fruit Bat. I don't know what to do.
Biology news on Phys.org
Hang up a wasp trap. Those yellow things you get at the hardware store.
EDIT -- and put one outside near that window too.
Oh, I hadn't even thought of that. It's all brick on the outside though, the window frame is (vinyl?), not wood. I wish I could figure out where they are coming in, I find them all around the window, but the ones the fruit bat got were towrds the living room. I was thinking they were coming out of the fireplace, perhaps had a nest in the chimney, but then why do they all go to that one window?
You might tape plastic over the entire window and see if that traps them. There is probably a crack between the window frame and the building somewhere... probably behind the molding.
When bees and wasps get in a house they usually head for a window. Could they be getting in somewhere else and this window happens to be the closest?
Definitly use the traps.
I was visiting a colleague yesterday. He remodeling his house, and he said that when they took of the siding they found all sorts of insects including bees and wasps.
As Ivan indicated they get into the wall through cracks and can find cracks/passages into the house. We've only had very few do that, but I've seen wasps building nests around parts of the siding - and I found one group building a nest in joint between two cinderblocks. The mortar had warn away and there was a hole just the right size for a wasp to crawl through.
Once inside they'll go to the window - usually with the most light. So in the morning, they go east and in the afternoon west. And you're more likely to find them on the south side of the house.
I could see one or two getting in through a crack, but we're talking about dozens seemingly at once. I've never seen anything like it.
It's the large number that concerns me with my pets.
This is not good Evo, The wasps are finished with their reproduction duties and having nothing to do anymore, they are just looking for trouble.
In Holland we would just call pest control. Perhaps try this.
Another tip... Take some incense and hold it by all the window and door frames to see where there could be a draft. Any place that you find a draft, close it up with sealer or something. I think those buggers are like mice and rats where they can squeeze through tiny holes.
And...
You have a pet bat? For real?
Good idea!
[quoteYou have a pet bat? For real?
No, he's just a tiny dog that loves fruit.
but there are 2 different rumors going around. 1.) Evo turns into a bat late at night and 2.) Evo turns people who make her mad into bats.
3.) Evo drives people batty.
Beware the blue eyed, long-tailed, crotch-dwelling froot bat. :biggrin:
If you're finding that many, there must be a nest somewhere, and it could be in a wall.
Have you looked in the window frame itself? One place I've had insects set up shop is in that space where the tension springs for the windows run. Usually, there's something over it to cover up the cords or springs, and you wouldn't immediately realize if there was a wasp's nest tucked down in there.
But, it's not Dr. Foofer and the Fruit Bat that I'm worried about. They seem able to take care of themselves. You're the one I'm worried will wind up stung if you try to take care of it yourself. This is something the apartment owners should take care of, so make them deal with the exterminators while you're safely at work.
If you are careful you won't get stung, go for it. Nobody likes a coward.
I got home and the wasp attack has ceased. I guess Dr Foofer and the Fruit Bat got them all. The Fruit Bat just found a dead one and was attacking it. Apparently they really ticked him off, he was pretty vicious, you DO NOT want to make him angry.
:devil: I'll remember this.
You'll remember that I'm the only one who had faith in you? wow, I'm touched.
Aw, see now, you made me feel bad. :frown:
I've had wasps lately too. I'm pretty sure they get in through a space between the screen door and the door frame but they almost always go straight for a window. Not sure why they come in in the first place. Be careful. Check and see if maybe there is an exterminator in your area that does free inspections.
Wasps like those small holes on the bricks that serve for something to do with rain , may want to check there.
Illustrating the thread
How cool is that...you can see she's got the spiky punk-look "hair" going on there.
I'd look twice before drinking out of that bottle!
Geeze o pete! I've been kiling wasps all day!
The Fruit Bat goes nuts when he sees one and starts to attack them, or starts barking if they're out of his reach. It's cute, I say "DANGER" and he scoots back and waits for me to get the wasp spray.
You have wasps at this time of year!?
Whereabouts do you live again?
It seems like they are getting in from outside the desk area. I would just spray around the window and any possible openings on the outside of the house twice a day. Morning and after work.
I'd be calling an exterminator if there were wasps coming in this time of year. That would suggest to me they are living in the walls someplace protected from the weather.
I live in Kansas. We haven't had a freeze yet, it was in the 70's today.
I have no idea what 70 is in celsius.
Well, let's hope that freeze kicks in soon.
Please tell me the name of the spray that you can use indoors. This will solve so, SO many of my problems in life.
jasonrox said:
i have no idea what 70 is in celsius.
~21 c
Moonbear said:
~21 c
That's warm! That's like ideal temperature.
  • · Replies 24 ·
  • · Replies 123 ·
21K
