Can Time, Mass, and Matter Exist Separately?
  • Context: Graduate
  • Thread starter Thread starter kamonra
    Mass Matter Time
The discussion revolves around the relationships and definitions of time, mass, and matter, exploring whether these concepts can exist independently or are intrinsically linked. Participants consider theoretical implications, particularly in the context of the Big Bang and gravity, and engage with classical and potentially quantum perspectives.
  • Some participants question whether time can exist without movement, suggesting that without movement, there would be no distance or time, particularly before the Big Bang.
  • Others propose that mass exists independently of gravity, defining it in terms of inertia rather than weight, and argue that mass is a property of an object regardless of its gravitational context.
  • One participant challenges the notion of zero gravity, suggesting that there may always be some gravitational influence, even if it is imperceptibly small.
  • There are discussions about the fundamental nature of dimensions, with some suggesting that if a new dimension can be defined in terms of existing ones, it may not need to exist independently.
  • Participants explore the implications of a universe with no movement, questioning the meaningfulness of distance and time measurements in such a scenario.
  • Some assert that time is a dimension that began with the Big Bang, while others argue about the conceptualization of "before" the Big Bang if time itself did not exist.
  • The relationship between weight, matter, and gravity is debated, with some asserting that matter is an intrinsic property while gravity is a force resulting from the curvature of space-time caused by matter.
Participants express multiple competing views on the independence of time, mass, and matter, with no consensus reached regarding their definitions or interrelations. The discussion remains unresolved with various hypotheses and interpretations presented.
Limitations include unresolved assumptions about the nature of time and gravity, the definitions of mass, and the implications of a universe devoid of movement. The discussion also reflects a mix of classical and potentially relativistic or quantum considerations without definitive conclusions.
kamonra
I was pondering the defining of time, mass, or matter ... wondered if anyone could help ...
However! First ponder this.
obviously speed = distance divided by time ... and ... mass = weight x gravity
The first question i ask. Can one of these variables(in their respective equations) exist without the other? for ex. If there was no movement then there could be no time. Obviously there is no distance .. since there is no movement. Then in the beginning was there no time .. before the "proposed" big bang theory.
My friend argue there was still time but not in the sense we could comprehend. ? any theories ...
propose you were in the middle of space ... where there were zero gravity .. then you would have no weight ... but wouldnt'y you still have mass .. or would you be massless ? obviously you are still there.. so maybe there's is no such thing as zero gravity .. . So my question is .. is there always gravity on a body .. maybe like a " limit" process so minute to you seem weightless but really you are not. therefore you would always have mass ...So then What is matter .. ? i only ask that if one could prove zero gravity can be obtained.
i would think that mass and force would be defined in terms of each other.
the question of what diemensions are fundamental and why they are fundamental is very interesting.
when a new fundamental dimension is defined in terms of other fundamental dimensions there is always a constant relating them. like the gravitational constant. if that constant is in reality everywhere equal to one then does that new fundamental dimension even need to exist? i would think obviously not. what if everything actually moves at the speed of light? would velocity be seen as a constant relating distance to time? so maybe time is unnecessary. hope that made sense.
Mass exists independent of gravity. A better definition than weight times gravity, in the classical sense, would come from Newton's second law. Mass is the amount of inertia an object possesses, that is, its resistance to acceleration.
Of course, acceleration is derived from measurements of distance and time. So mass is intricately tied to those two as well (or those two are intricately tied to mass).
When considering whether or not there is movement in a universe and the implications that has for distance/time measurements, I think you have to consider a reference frame. If there is SOMETHING in the universe, surely there will still be distance. However, if there is nothing there is nothing to measure with respect to and the notion is meaningless. Time and space (distance) are intrinsic properties of our universe. They are simply the 4-D coordinate system we live in (x,y,z,t), so at least in our universe they will always be there.
This is all classical, and I haven't considered at all any quantum or really even relativistic effects. But I think this still has a lot of ground underneath it.
Different, not better.
F=m1a [m1: 2nd law mass or "inertial mass"]
F=GM1M2/r2 [M1,M2: gravitational mass].
It is experimentally true that m1=M1.
A particle that is (infinitely) far from any other masses has both inertial mass and gravitational mass - these are properties of the particle.
When it comes into the gravitational field of another particle, it will feel a gravitational force, which we call weight.
I'd argue that "beginning" is a point in time. Without "Time" how do you begin?
So i'd say time began with Big Bang. Time is a dimension...Hence "space-time"
And then i'd also ask how can you have a "before" Big Bang...If you claim there wasn't time.
As far as the weight and matter. Weight = Matter x Gravity.
Meaning Matter and Gravity are two separate things. Matter is the intrinsic property of an object. Matter is directly proportional to inertia, and inertia is our resistance to a force. Gravity is a force caused by curvature of space-time. Which is what matter causes...
F = G[(m1/r^2)(m2/r^2)] Gravity is due to mass.. not mass itself.
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 190 ·
18K
