HELP: Normal Force/Tension/Work Problem
  • Thread starter Thread starter ctpengage
    Normal
The problem involves a block of cheese on the floor of an elevator cab, focusing on the concepts of normal force, tension, and work done by the cable as the elevator moves upward. The discussion centers around two parts: calculating the work done by the cable and determining the normal force under different conditions.
  • The original poster attempts to understand the reasoning behind the normal force calculation in part two, questioning why the acceleration is considered zero. Other participants explore the relationship between normal force and weight in the context of the elevator's motion.
Participants are actively discussing the implications of the elevator's acceleration on the normal force and the conditions under which the normal force equals the weight of the cheese. Some guidance has been offered regarding the frame of reference and its effect on the calculations.
There is mention of a specific textbook problem and a provided solution, which may influence the understanding of the normal force in relation to the weight of the cheese and the elevator's motion. The original poster expresses concern about the integrity of the problem context.
ctpengage
Hey there guys.
Our teacher gave us an example problem to which he provided the solution for us to study.
The question is:
A 0.250 kg block of cheese lies on the floor of a 900 kg elevator cab that is being pulled upward by a cable through distance d1 = 2.40 m and then through distance d2 = 10.5 m. (a) Through d1, if the normal force on the block from the floor has constant magnitude FN = 3.00 N, how much work is done on the cab by the force from the cable? (b) Through d2, if the work done on the cab by the (constant) force from the cable is 92.61 kJ, what is the magnitude of FN?
The solution is:
(a) The net upward force is given by
Ftension + FN -(m + M)g = (m + M)a
where m = 0.250 kg is the mass of the cheese, M = 900 kg is the mass of the elevator cab,
Ftension is the force from the cable, and FN is the normal force on the cheese. On the cheese alone, we have
FN - mg = ma
Reaaranging and subbing in known values yields the acceleration as 2.20m/s2
Thus the force from the cable is
Ftension= (m+M) (a+g) − FN =10800N and the work done is therefore
10800N x (2.4m) = 25900J
I understand part 1 but I don't understand the solution to part 2.
Solution Part 2:
If W = 92.61 kJ and d2 =10.5 m , the magnitude of the normal force is
FN = (m+M)g - W/d2 = 2.45N
I don't understand the solution to part two at all. It seems that for part two, the acceleration of the cheese and elevator cab is zero. Why?
Can anyone help clarify issues with this problem.
Thanks
For guys who think I created some sort of fake scenario above to get you guys to help me cheat or something, the problem is no 25, chapter 7 from Fundamentals of Physics 8ed Extended and is a tutoring problem whose solution our prof. made available on WileyPLUS.
please guys help ere :D:D:D
We just got to this problem in my AP physics course. I thought the same thing as you when I arrived at the answer and checked it with the back of the book. The back of the book says that the normal force is equal to the weight of the cheese. The only way that is possible is if the accelerate or mass is zero. Since the mass is obviously not zero, it must be the acceleration. It then dawned on me that it must be because the acceleration of the cheese with the elevator cab as the frame of reference is zero. So then Fn= -mg = 2.45N. If you used no frame of reference the answer you should have arrived at is 4.902N.
  • · Replies 19 ·
