How can I find the impact parameter in hyperbolic geometry?
The discussion revolves around finding the impact parameter in the context of hyperbolic geometry, specifically relating it to the hyperbolic semiminor axis.
  • The original poster expresses uncertainty about how to relate the parameters a and b, considering the equation provided. They mention the Pythagorean theorem but are unsure how to apply it to derive the impact parameter. Another participant suggests analyzing a general hyperbola and calculating the distance from the vertex to the asymptote to find the impact parameter.
The discussion is ongoing, with participants exploring different interpretations and approaches to the problem. Some guidance has been offered regarding the geometric properties of hyperbolas, but there is no explicit consensus on the method to solve the problem.
The original poster indicates a lack of clarity on how to connect the given parameters and equations, which may suggest missing information or assumptions that need to be addressed.
ColdFusion85
Prove that the magnitude of the impact parameter B equals the length (-b) of the hyperbolic semiminor axis.
|B|=|b|=|a|sqrt(e^2-1)
I really don't know where to start. I was thinking of finding a relation between a and b but that is just the right hand side of the equation above (for hyperbolic geometry). I was thinking about the Pythagorean theorem, but then I don't know how |B|=|a+b| would become |a|sqrt(e^2-1). Could anyone help me along the right direction? Thanks.
Anyone?
bumping one more time, is there anyone out there that can help?
I would do it this way. Take a general hyperbola in standard position. x^2/a^2-y^2/b^2=1. That puts a vertex at the point xy point (sqrt(a^2+b^2),0). An asymptote is the line y=bx/a. The impact parameter is the distance from the vertex to the asymptote line. If you work that out you should get b. Which is the semi-major axis.
  • · Replies 18 ·
