For you maths-people as I'm confused.
  • Context: Undergrad
  • Thread starter Thread starter Lorentz
    Confused
The discussion revolves around the representation of numbers, particularly the fraction 1/3, in different numeral systems and the implications of these representations on accuracy. Participants explore the differences between fractional and decimal representations, the concept of repeating decimals, and the limitations of numerical systems in accurately depicting certain values.
  • Some participants express confusion about why 1/3 can be represented accurately as a fraction but not as a finite decimal.
  • Others argue that the notion of "accuracy" in representation is subjective and depends on the context of use.
  • A participant mentions that certain fractions cannot be accurately displayed in finite decimal form in various numeral systems, leading to issues in computational contexts.
  • There is a discussion about the notation for repeating decimals, with some asserting that 1/3 can be represented as 0.\bar{3}, while others challenge the equivalence of 0.\bar{9} and 1.
  • Participants provide examples of how different bases affect the representation of numbers, noting that some values require infinite digits in certain systems.
  • One participant highlights that in computer calculations, rounding occurs due to the inability to represent certain decimals exactly.
  • There is mention of alternative notations for recurring decimals, with some preferring dot notation to reduce errors in manual writing.
Participants do not reach a consensus on the equivalence of certain decimal representations, particularly regarding 0.\bar{9} and 1. The discussion reflects multiple competing views on the accuracy and representation of numbers across different systems.
Limitations include the dependence on numeral systems and the unresolved nature of how different representations affect mathematical operations and computational accuracy.
Lorentz
How is it possible that I can write (for example) 1/3 and be 100% accurate while I couldn't write the same number in decimals being just as accurate?
It has to do with our choice of system. But what is it exactly? I don't seem to grasp it or isn't there anything to grasp?
Mathematics news on Phys.org
it's nothing to do with a deficiency in the representative powers of the system, but with your intent to use a word such as "accurate" and hope it means something mathematically for it to translate as 'looks pretty' and 'doesn't take up too much space on the paper'.
Thanks for clearing that up... though I still think it's weird.
There isn't anything to grasp, depending on the system you use, you will not be able to accurately display certain fractions, like for example 1/3 in both binary and decimal system you would need an infinite amount of numbers. That is an entire issue when doing math in the computer and one that has already frequently caused me problems. It is not weird, just plain annoying.
Can't you write it in decimals like this:
[tex]\frac{1}{3} = 0.\bar{3}[/tex]
Aren't both ways 100% accurate?
Or you could write it
[tex].1_3[/tex]
That's base 3. The existence of the real number line is independent of the any representation of points on the line. In a Real Analysis course, where the properties of the Real Line are explored in depth, such representations are not used, thus the results apply to all representations.
Actually, I don't think that's true. If you multiply your equation there through by 3, you'll see why.
please say you're not about to start another pointless 1 is not equal to 0.999... thread. they are equal, end of story
Yeah:
[tex]1=0.\bar{9}[/tex]
I think that's an often asked question. But it's true. Or that's what they tell me.
Before you go there, it is true and there are many many proofs that as stated above [itex]1=0.\bar{9}[/itex]. If you are interested please try and learn them and see why they are right then just trying to argue them wrong illogically.
Ok, I apologise for making that comment. I found a proof, I'm convinced!
Does this notation mean: 0.999999... (going on infinately) ?
You can't get exactly 1/3 exept through drawing eg.
Triangle with two 1cm sided sides and a hypotonuse the Hypotonuse will be exactly = to Sqrt of 2
Yes, that's the so-called "bar" notation. The line indicates a repeating sequence of numbers. Here is another:
[tex]\frac{1}{11} = 0.\overline{09}[/tex]
Here two digits 09 repeat continuously (0.09090909...).
As mentioned above, in every base, there are some points on the Real line which cannot be represented in a finite number of digits. A very interesting example of this is:
[tex].1_{10} = .000 \overline {1100}_2[/tex]
The implication of this is that any time .1 is used by a computer in a calculation it MUST be rounded off.
Accurate Representation
Of course, you could write 1/3 as .3 with a bar over the three to represent an unending decimal, but this is again just a mater of "what looks pretty," and has nothing to do with the calculations in a computer. You see that 0, and 5 are divisable in base 10, and thus, 1/2 = .5. Now if you want to do math to the base 3, then we have 1/3=.1 (base 3) same as we have in base 10, 1/10 = .1 (base 10). By changing bases we solve such problems!?
For reference bar notation isn't the only way of writing recurring decimals:
[tex]0.\bar{3} = 0.\dot{3}[/tex]
[tex]0.\overline{30} = 0.\dot{3}\dot{0}[/tex]
[tex]0.\overline{307} = 0.\dot{3}0\dot{7}[/tex]
I think it's preferable to use dots when writi git out by hand as it makes mistakes less likely.
  • · Replies 105 ·
12K
  • · Replies 57 ·
