Calculating Concentration of Ba(OH)2 from Titration with H2SO4 Solution
  • Thread starter Thread starter briteliner
    Concentration
The concentration of Ba(OH)2 can be calculated using the titration data provided, where 7.85 mL of 0.102 M H2SO4 is required to reach the equivalence point. The normality of the H2SO4 solution is determined to be 0.204 N. By applying the neutralization equation N1V1 = N2V2, the normality of Ba(OH)2 can be found, and subsequently, the molarity can be calculated by dividing the normality by 2. This method provides a clear pathway to determine the concentration of the Ba(OH)2 solution.
  • Understanding of titration principles
  • Knowledge of normality and molarity calculations
  • Familiarity with the neutralization reaction between acids and bases
  • Basic skills in stoichiometry
  • Study the concept of normality in acid-base reactions
  • Learn about stoichiometric calculations in titration
  • Explore the properties and reactions of Ba(OH)2 and H2SO4
  • Review examples of titration problems involving strong acids and bases
Chemistry students, educators, and professionals involved in analytical chemistry or laboratory work focused on titration techniques and concentration calculations.
briteliner
given a 10.0mL sample of Ba(OH)2 solution, calculate the concentration of the solution if it took 7.85mL of a .102 M H2SO4 to reach the equivalence point
You just don't ask. You try, you tell us what you did, we push you in the right direction.
I'm going to assume you have no clue how to start this problem, seeing as you did not attempt it.
Because both compounds have an equal number of Hydroxides/Hydrogens the normalities would be the same, nevertheless I'll go through normality just to show you.
Normality(N) = Moles on Hydroxide/Hydrogen(n) * Molarity(M)
So the H2SO4 solution is .204 N.
The neutralization equation is N1V1 = N2V2
So, (.204 N) * (.00785 L) = (X N) * (.0100 L)
Find X, then divide it by 2 to get Molarity.
OR...
You can just go through moles because they have the same Normality.
Molarity(M) = Moles(n)/Volume(L)
Take your Molarity and multiply it by your volume. That gives you moles so you can set up another Molarity equation.
Good luck, now you should have all the tools you need!
