One dimentional problems(flow) in CFD
  • Thread starter Thread starter mahaesh
    Cfd
One-dimensional flow problems in Computational Fluid Dynamics (CFD) refer to scenarios where fluid variables change in only one direction. Common examples include Couette Flow, where fluid is sandwiched between two moving plates, and the General Heat Equation, which simplifies under steady-state conditions. While 1D CFD solvers are limited to geometries like straight tubes, they are valuable for understanding the behavior of spatial and time derivatives. Advanced techniques, such as pseudo-2D codes, can enhance simulations by incorporating variable area effects, exemplified by choked nozzle simulations.
  • Understanding of Navier-Stokes Equations
  • Familiarity with Couette Flow concepts
  • Knowledge of the General Heat Equation
  • Experience with CFD solvers and numerical methods
  • Explore the implementation of Couette Flow in CFD software
  • Learn about the General Heat Equation and its applications in thermal analysis
  • Investigate the development of pseudo-2D CFD codes
  • Study the behavior of spatial and time derivatives in fluid dynamics
Researchers, engineers, and students in fluid dynamics, particularly those focused on CFD applications and one-dimensional flow analysis.
mahaesh
Hi everyone
My question is
What is the meaning of one dimensional problem(flow)? Can one dimensional problem(flow) solve in CFD? If the answer is yes then How?
Any 1-D flow is simply flow where the variables only change in one direction. Look at the common Couette Flow, which is typically used to introduce analytic solutions to the Navier-Stokes Equations.
In this flow, the fluid starts at rest between two plates. At t=0, the top plate moves at a velocity U. If you assume that the plate is infinitely deep and long, then the flow only changes in the vertical direction between the plates.
From another standpoint, one can look at the General Heat Equation, which I believe looks something like:
[tex]\frac{\partial^2 T}{\partial x^2} + \frac{\partial^2 T}{\partial y^2} +\frac{\partial^2 T}{\partial z^2} = \frac{1}{\alpha}\frac{\partial T}{\partial t}[/tex]
If you consider a case like a flat wall, i.e. a very tall wall in your house. You can assume that there is no change in the vertical direction and no change "into the page." If you then assume that the solutions is steady state, you're left with the much simpler equation:
[tex]\frac{\partial^2 T}{\partial x^2} =0[/tex]
1D CFD solvers can't typically solve much though. I the flow is 1D, then the geometry must also be 1D. That means essentially you have a long staight tube. Nothing really happens.
With that said, a 1D solver for the wave equation is extremely useful in learning how spatial and time derivatives behave. I have written one, and I can probably assume most people who have studied it have as well.
Beyond that, one can write a pseudo-2D code, which at that point can be extremely cool. A code like this solves the equations in 1D, but then adds a source term which simulations a change in area. My old CFDII final was this project. The area was in such a way that it simulated a choked nozzle. The results were perfect.
  • · Replies 45 ·
