Faraday's law and complex number
The discussion revolves around the implications of introducing complex numbers, specifically the imaginary unit "i", into Faraday's law of electromagnetic induction. Participants explore whether the presence of "i" in mathematical expressions derived from physical laws has any meaningful interpretation, particularly in the context of induced electromotive forces (emf) and the behavior of electric fields.
  • One participant suggests that taking the square root of both sides of Faraday's law introduces an imaginary component, questioning its significance.
  • Another participant argues that the presence of "i" can be eliminated under certain conditions, such as when the integral of the electric field or the rate of change of magnetic flux is positive.
  • Several participants inquire about the conditions under which the integral of the electric field might be negative or positive, and how this relates to the sign of the derivative of magnetic flux.
  • There is a discussion about the meaning of "dl/dt" and its relevance to the original equation, with some participants expressing confusion over its interpretation.
  • One participant mentions that in RCL circuits, imaginary values can represent sinusoidal solutions, but questions the physical meaning of these imaginary quantities.
  • Another participant explains that complex numbers can indicate direction in two-dimensional problems and have physical significance in various contexts, such as wave propagation and quantum mechanics.
  • There is a contention regarding whether both the integral of the electric field and the rate of change of magnetic flux can be positive simultaneously, with differing opinions presented.
The discussion contains multiple competing views regarding the interpretation of "i" in the context of Faraday's law and its implications. Participants express differing opinions on the conditions under which the integral and the derivative can be positive or negative, and the relevance of complex numbers in physical equations remains unresolved.
Participants highlight the complexity of the discussion, noting that the introduction of complex numbers can lead to confusion, particularly when considering the physical meaning of imaginary components in equations. The debate also touches on the conventions used in physics regarding signs and directions.
spidey
Faraday's law is ∫ E dl = - ∂Ф/∂t
if we take sqaure root on both sides,
√∫ E dl = √- ∂Ф/∂t
√∫ E dl = i √ ∂Ф/∂t
Now the r.h.s has "i" in it. Does this mean anything? Having "i" in a equation means anything?
I have seen "i" in Schrödinger equation and dirac equation. As like those equations, does the above equation also has any meaning?
We don't really have an i, because one of the following will be true:
∫ E dl is negative, so √∫ E dl also gets a factor of i. Divide both sides of the equation by i, and there will be no more i's.
or
∂Ф/∂t is negative, in which case -∂Ф/∂t is positive, and
√ -∂Ф/∂t = √ (a positive value) → no factor of i
or
∫ E dl and ∂Ф/∂t are both zero → no factor of i
Of course, you could save a lot of trouble by not taking the square root in the first place!
1) Under what conditions would ∫ E dl be "negative"?
2) Under what conditions would ∫ E dl be "positive"?
3) What is the sign of dl/dt in both cases?
Regards,
Bill
Bill,
Are you familiar with induced emf's and Lenz' Law? That's the type of situation where ∫ E dl is nonzero.
Mark
Hi Mark,
If E is propagating, dl/dt is not zero. The questions have to do with what your sign convention is.
Regards,
Bill
or
or
supposing for this case ∫ E dl and ∂Ф/∂t are both positive, then -∂Ф/∂t is negative and so it will have an i. Under this condition, does this have any meaning?
My basic question is, not only for this equation, for any equation in physics,if it has an "i",then what it tells us?
I would assume that dl/dt is negative in that case. I think that is the standard physics/optics convention.
Regards,
Bill
spidey said:
supposing for this case ∫ E dl and ∂Ф/∂t are both positive ...
They can't both be positive! Because
∫ E dl = -∂Ф/∂t
so if one is positive, the other must be negative.
Not true if dl/dt is positive. Care to show otherwise?
Regards,
Bill
Since dl is a vector (a length element with a direction), how does it even make sense to talk about dl/dt being positive?
But the problem with the OP's question is: given any equation in physics with a "-" sign on one side of the equation. Take the square root of both sides of the equation, and now you have a mysterious factor of "i", and he is trying to find meaning in that. For example, F=-kx for a spring.
Because the notion of "propagation" has a direction too.
Regards,
Bill
Bill,
I'm having trouble following your argument, beginning with this statement:
Antenna Guy said:
Hi Mark,
I am not even sure what dl/dt means at this point. I thought you were describing a situation where the closed path of the integral is moving and changing shape.
If so, I think this unnecessarily complicates the OP's question because dl/dt does not appear in the equation in question,
[tex] \int \vec{E} \cdot d\vec{l} = - \ \frac{d\Phi_B}{dt}[/tex]
Anyway, could you clarify what dl/dt is for me? Let's make sure we're talking about the same thing.
the minus sign is only to get the directions right, it's not that important, even less important when you take the square root of it =o
it's usualy more convenient to use avsolute values in such equations, and find the direction later.
about your question, I know that in RCL circuits' equations "imaginary" solutions are taken in cosideration aswell, imaginary currents, imaginary resistance, and stuff like that.
I think what it means is that these solutions (currents, resistances) are sinusoidal , but I'm not sure what's the physical meaning of these "imaginary values" if there is one at all, or maybe at the end only the real part of the value is taken, I'm not sure.
Redbelly answered this question already when he told you
∫ E dl = -∂Ф/∂t
In many 2 dimensional problems, real and imaginary parts are used to indicate direction. For instance, in exp(i*phi)=cos(phi)+i*sin(phi), you can plot real and imag parts on the x and y axes, respectively. This is used to solve problems in potential theory (through conformal mapping, for instance). Elsewhere, real and imaginary indicate in-phase and quadrature components of a signal or a field. There are many other examples, some of them more subtle.
In other cases, real and imag parts indicate allowed and non-allowed modes. A light wave hitting a polished metal surface will reflect. The incident and reflected waves have real propagation constants; the evanescent wave that penetrates a nearly infinitesimal distance into the metal cannot propagate and is described by an imaginary propagation constant.
ibc mentions correctly that i is sometimes used as a bookkeeping tool and that the real part of an expression is taken at the end to find the physically significant quantity.
In short, i definitely has physical meaning in many cases.
Regards,
Bill
Regards,
Bill
You might profit from review of your E&M texts. First of all, see Redbelly's responses. Second, there's no propagation here--Faraday's law deals with the line integral of the field around a fixed path L that may be physical (a wire) or virtual.
As indicated by marcusl, complex numbers give directions in planes. When you have a factor "i" in a differential equation for a vector or vector derived function, it means that the vector differential is at an angle 90° to the vector itself. I've tried to make that clear in my video clip on the "www.youtube.com/watch?v=JmEMVJYbTu8"[/URL]. Excerpt: "There is the operation where the arrow is rotated by an angle alpha. We multiply ket |A> by a so called complex number to describe this rotation: exp(i alpha). So when you see a complex number in quantum-mechanical expressions, it is real physics. It simply means that ket |A> has undergone a rotation in its spinning surface."
