Particle Collision: 3.00kg & 4.00kg Particles
The discussion centers on the collision of a 3.00 kg particle with a velocity of v = (-4.00 m/s) i + (-5.00 m/s) j and a 4.00 kg particle with a velocity of v = (5.60 m/s) i + (-1.80 m/s) j. To find the final velocity after the collision, the momentum formula p = mass * velocity is applied, leading to the equation vf = (p1 + p2) / (m1 + m2). Additionally, to determine the angle of the resultant velocity, the tangent function is utilized: tan(θ) = p2 / p1, with θ calculated as θ = tan^-1(p2 / p1).
  • Understanding of momentum and its formula (p = mass * velocity)
  • Familiarity with vector addition and subtraction
  • Knowledge of trigonometric functions, specifically tangent
  • Basic understanding of Pythagorean theorem for magnitude calculations
  • Study the principles of conservation of momentum in collisions
  • Learn about vector addition in physics, including unit-vector notation
  • Explore the use of trigonometric functions in physics problems
  • Investigate the application of the Pythagorean theorem in calculating resultant velocities
Physics students, educators, and anyone interested in understanding particle collisions and momentum calculations in mechanics.
cgarr017
Particle Collision Two A collision occurs between a 3.00 kg particle traveling with velocity v = (-4.00 m/s) i + (-5.00 m/s) j and a 4.00 kg particle traveling with velocity v = (5.60 m/s) i + (-1.80 m/s) j. The collision connects the two particles. What then is their velocity in each of the following notations?
(a) unit-vector notation
( wrong check mark m/s ) i + ( wrong check mark m/s ) j
(b) magnitude-angle notation
m/s angle ° (counterclockwise from the positive x axis)
I would show an attempt at the solution but i have no idea what the formulas are or where to start
nobody?
Hey a little late, but I think for this one you have to use
p= momentum= (mass*velocity)
vf = (p1 + p2)/(m1+m2)
for angle, use tangent.
tan(o) = p2/p1
(o) = tan^-1(p2/p1).
With respect to vector notation, i think you just add and subtract, but for angle use Pythagoras, cause you will need v1, and v2 as a quantity.
  • · Replies 31 ·
  • · Replies 22 ·
